Hi everyone,
I need to do some welding on my truck, replace some rusty lower panel sheet metal. I have it my garage which currently only has one outlet for lights. My welder is a Lincoln Electric, the power specs are confusing. but I know it runs 220. My garage is temporary as I am in the middle of construction and in a few months will be converted it to a room. Then down the line I will be adding an attached garage (12 feet over). My house is wired for 200 amp service. I need to figure out how to get power to my welder.
Looking at the specs it says to use a 40 amp breaker which means I will have to use 8/3 wire. The garage is roughly 65 feet from the main power box. With that sort of run do I have to worry about voltage drops? If so does that mean I have to go up in wire and breaker? I see the lines come in rolls of 125ft. I am wondering if I just leave the roll spooled up with the extra footage so I can use it when I build the garage down the road?
My father in law mentioned a generator which I also have but the specs on my generator running rate is 3850 watts and 4850 surge. Not sure based on the specs I have enough juice for startup.
