Show us your welding projects
1949 caddyman
Arizona
That's really cool. How did you form the branches? It is heating solid rod with a torch and hammer into shape? Make sure to post up the finished project.
We ran a longer bar of 1/2” steel through a tubing bender making slight bends & then cutting them off in random lengths. No heat required. Did the same with smaller diameter.
jalexl
Los Angeles, CA
I used some 1/8" wall 2" dia tubing... cut it at 45 and tacked 2 together to make a corner. Split the whole thing in half so I could get 2 feet out of section I welded together. Traced out my template on each side of the original 45 cut/weld on the inside of the tubing and roughed it out with a cut off wheel. Welded the feet to the bottom of the frame legs and beat the outside flat with a BFH. Finished with a grinding when and then flapper disc... clear as mud?
They were a lot of work but I really wanted them on there!
any chance you can explain that with a video or series of pictures?? they look real cool
jimgood
Marshall, VA
Had a need to scribe a large arc so I satisfied my primitive nature and made a tool. Nothing spectacular. Just a simple protractor. Quick and dirty and easy peezy lemon squeezy.
1/2" 16 ga. square tube
5/16" rod (5/16 key stock might work too)
1/4" bolts
I didn't have an extra scribe so I used a 9/32" transfer punch at one end
This wouldn't have cost me anything because I had all the materials on hand but I ordered two more carbide tipped scribes of the type at the left end of protractor because that one is the only one I have (cuz I never thought that I could possibly need two!).
View media item 80895
View media item 80896
View media item 80897
1949 caddyman
Arizona
Got the leaves made, hammered for texture & welded on friday. The rust spots are from cooling it down to put in my truck for the ride home. Not sure about the finish it will get.
Next week we make a sheet metal cut out using a plasma cutter. Mine will be a hotrod silhouette.
pepi
Woodstock, GA
Tungsten grinder for the walk of shame.
Just finished up a table top, 12 ton finger brake press. DIY brake by SWAG, frame by me;
Sjfab
St. Paul Mn
Built 4 of these davit arms for removing large heads from chiller bundles. The big head weighs 1800#.
Outer pipe is 5” sch. 120 and the inner pipe is 4” sch. 120. Notched the 4” to fit a 16”x45# beam that we cut down the center to make it a T beam. All welded on site with 7018.
Edit: Don’t know why the pictures are sideway.
FallibleFlyer
Arizona
Finally finished my new welding table, largest welding project I've done to date.
The frame it made of 16ga 1.5" square tubing and the top is three 0.5x12x27" plates.
quadrcr87
Travelers Rest, SC
First project on my new welding table! Making some garden art for the wife. I saw the idea on here and I’m putting my own twist on it.
BD1
north side
First project on my new welding table! Making some garden art for the wife. I saw the idea on here and I’m putting my on twist on it.
Nice !! That looks great. I have a couple more ready to assemble just need to do a base. I might use a flat rock for one.
quadrcr87
Travelers Rest, SC
Thanks for the plug. 😂 . Make her one ! I used 1/4" round,
3/4" Rebar, and strips of 20 gauge sheetmetal. Next ones
Used 5/8" Rebar , that's what I had left.
I used a 3/16" plate base, 16g sheet metal strips, 3/16" rod & 1/2" tubing. I built it a little heavy duty knowing it was going outside and will likely be moved around a lot over the years.
Hubscrub66
Tennessee
Turned out nice:thumbup:
12husky
Here is a candle holder I welded up for my wife for Valentine’s Day. I stole the idea from Pinterest. Now of course she has to repaint the wall.
12husky
Yes agree you killed that. Can't make out on my phone but us that all 1/4"
Round ? . Great job in forming all that .
I like your painting comment the best. [emoji23]
Yes, everything was made from 1/4” round. I ran it through my ring roller first to give it a tendency and then hand formed it to the spirals. The rings for the glasses I formed around a piece of solid and then welded up.
She was happy even with having to repaint the wall!
KMinAF
Fairview Utah
Neat idea! Ill have to include that on my "must make" list
Garagetime
New Hampshire
Built these shelf brackets. For a shelf on each side of the bed.
