Raisedonadeere
I have a two cylinder single stage Sears 125psi air compressor I have had since 1968. It has stayed in constant use, I changed the oil a time or two and replaced the regulator and fittings once. It has stayed in constant service all that time, usually full of air. It has done some roofing jobs but otherwise just blowing our air filters, running impact wrench, pumping tires to keep my 3 or 4 car/truck family going and an occasional sanding job. What is amazing about this compressor is that it still has the same drive belt that came on it. How can that be unless someone sneaked in my garage and changed it while I was away or sleeping?
I am well aware of the potential energy in a tank of compressed air. One friend lost a finger when a bicycle tire blew while airing it up. and a neighbor showed me a hole in a concrete block wall that his compressor blew out. The welds broke on that one. It was a fairly new compressor.
Mine does not leak, and other wise I am not knowledgeable on how one checks these things for safety.
I am wondering if because of age I should do away with it or if it is a matter of some sort of check for the condition of the bottom of the tank where water collects.
