dacan23
RI
Just get M12 6.0s! I am up to 7 6.0s.... you dont want to know how much I paid for them...
Don't worry, you'll get there.. I buy **** from them I know I won't even use.. like tire inflators..
And I got a great project for one of you guys with 3D printers.. stop making these milwaukee to Ryobi, or Milwaukee to Ridgid battery platform converters...
What you NEED to make - is a M18 to M12 battery adapter.. lemme throw a nice m18 pack on my m12 stick lights, or lantern, or m12 drill and impact driver... or m12 rotary tool.. or your underhood light !!
Someone get on this - I want one and I don't even use my regular printer, I'm not buying a 3D printer.. I have a new cell phone I haven't even activated since I got it for Christmas, I'll be 80 by the time I ever got around to 3D printing.
Here's a hint - merge the m18 power source, and get the upper half of an m12 4.0 mounted and wired on top of it.. but it's gotta look nice..
Here, make this, but not ******.. actually, it looks like you don't even need the m18 powersource. The bottom of the m12 4.0 pack looks like you'd be able to MAKE the m12 shell lock into the m18 battery with some small redesign..
Just think - one of you lucky geeks can be the CO-creator of Milwaukee's new sub compact 18v line...
one9gt
San Francisco
Newest pickups. M12 was a whole kit with 4.0 and free 2.0. Luckily found the 9.0 promo kit on clearance at 217.
Mohawk Dave
SoCal
LOL. It's certainly doable. Would require some electronics to convert the 18v to 12v... wouldn't necessarily be efficient though.
I never did get around to selling the ryobi adapters though. I ordered some parts, ended up getting the wrong stuff shipped, was resent the parts and they got it wrong again.
Hey plc268,
I still really want to buy 1 or 2 M18 to Ryobi adapters when you're ready. I already bought the green fan and glue gun.
kctyphoon
Jersey/Staten Island
Right angle m12 just showed up... honestly, it's a lot heavier then I thought it would be.. no complaints about that - just kinda took be by surprise how heavy it actually is.
DFB
Southern VT/Western Mass
I can't believe there isn't a RA Fuel that's balls to the wall superior fill the gap between the brushed M18 2 speed 3/8 and the cordless Hole Hawgs
kctyphoon
I can't believe there is a more powerful RA impact like the IR hammerhead.
Did anyone else know you can buy 37 or 39" long Bosch sds plus bits? I just bought a 3/8" and 3/4".. a lot cheaper than I excepted, the 3/8 was only $19... go figure.
1TMF
Anyone have the M12 Rotary tool? If you do would you recommend it or is it better to wait for a FUEL version?
I've enjoyed my rotary tool as it generally works well, uses M12 batteries, and you can still use dremel accessories.
However, I think I mine might be toast (I haven't used it that much... Just a few small projects... Sanding wood, trimming some metal with a cutting disc, and little bit of grinding to clean up sharp edges.). When I set the rpm dial, I can hear the rpm of the tool going up and down on its own (with no pressure on the bit). Has anyone else had this issue? Might be time for a warranty claim.
redvalkyrie
I just can’t believe that both the M12 & M18 right angle drills don’t have 1/2” chucks.....
I am with you on this. I was searching for a battery powered right angle drill with a 1/2" chuck and had to go with a Bosch. It works great but it would have been nice to have been able to keep it in the family. Now I have one more battery system to charge...although, the Bosch has been charged once since new. That includes drilling out a cylinder header for time serts and the cleaning of numerous surfaces with a 3M disc.
Bighead38
Rockland County NY
Check this out - notice their "one key adapter" and different jigsaw..
https://uk.milwaukeetool.eu/NetC.Mi...ary/Downloads/MWKUK_HDN_2018_Q1-2_DIGITAL.pdf
And good, glad to hear your friend is ok.
Some cool stuff. Different jigsaw, m18 magnetic drill, m18 planer, the m12 with interchangeable chucks, etc. I’m jealous they get the black and red cases. So much cooler than red and white. Speaking of cases I wish the case I got with my tools wasn’t molded. I don’t use it for the drill and impact and would love to repurpose it.
intillzah
Larned KS
I got a m12 ratchet here a while back, I love it. Sure saves a lot of time when you are disassembling something.. I'm thinking about the m12 3/8th impact next, and a higher amp battery for the impact, I just wonder if the impact will do for tire rotations?
DFB
It WILL remove clean and properly torqued wheel lugs upwards towards 100ft lbs. with some slight effort but consistency may vary. I have done trailer wheels easily enough with mine others have posted on GJ here that they have not had success removing the lugs within that range on certain factory installed wheels.
Tool of choice for general tire rotations?...No
Occasional jobs...depends on a myriad of factors :D
Much better off with an M18 impact wrench and even the compacts sometimes don't cut it either. Especially on trucks
intillzah
Larned KS
Probably stick with my corded impact then, I going to start rotating tires myself on my Sonoma twice a year..
dacan23
RI
No you cant get this, one of a kind. Got this through a special Milwaukee prototype program through fisher price.
DFB
Nothing wrong with corded guns if your near electric
I been hawking these corded impacts under my tool tent. And I have been pretty impressed with the performance. They work as good or maybe even a better than the compacts cordless units rated at 220 ftlbs. I have both 2655B and newer 2754. And much better than a big ol' old rocker switched electric unit similar to what HF sells. I had bought years ago
:thumbup:
toddoky
Bowling Green, Kentucky
I'd like to report that the various Milwaukee M18 lights I own worked out well to get the family through a power outage last night that came as part of the storm/tornado warning that came through our part of Kentucky last night. The stick latern was especially useful in providing light and the USB port to charge my phone that would have gone dead otherwise since the power was out for about 4 hours.
Jamie V
Atco, NJ
The Milwaukee addiction thread! 😊
I have M18 fans in my 3 daughter’s bedrooms that they use to help sleep at night (we live on a busy road) and they work perfect on battery power when we loose power from time to time!
dacan23
RI
Everyone know the M18 radius hit $150 last week at HD? I negotiated a nice display model for $110.
PR1Gneon
Sent from my SAMSUNG-SM-N920A using Tapatalk
Crazyjake8493
Upstate NY
Well I have two of them now, the one key is cooler but more exp.
Rocket tower gen2 down to 200, orig 400.
M12 4bay charger 56
Depends on the store and region, but I believe our closest store has the same price. I know the 4-bay charger is $56, saw it today. And the M18 Fuel SDS rotary hammer is down to $225.
