Best Air Compressor Anti-Vibration Pad ?
427HISS
Getting tired of my 60g compressor walking around the garage.
So, I want to anchor bolt it down and set the legs on anti-vibration pads, question is, what are the best pads to buy or make and why ?
What material is the best ?
How thick ?
Do you screw the bolts down tight, or leave a tad loose ?
larry_g
oregon
I grabbed a blown retread from off the side of the road. Cut some squares from that to use as pads under a couple of machines, worked great. Search out machinery mounts, that is the correct style of pad to use.
lg
no neat sig line
IowaDon
SW IA
Copy and paste this into Google:
compressor pads site:garagejournal.com
There are a lot of options.
Jason280
Go to Tractor Supply, and pick up a small piece of their thickest bedliner material...cut to fit under the feet of the compressor, and bolt it down.
The Tool Tyrant
Bonita, Ca. (San Diego)
As I'm obsessed with my compressors being level and each foot evenly loaded, I prefer the 2 part pads which allow me to shim between the pads until all four pads are perfectly level with each other BEFORE I sit the compressor onto the pads. I then check the pump platform for level in both directions, then use nylock nuts on the wedge anchors, run them down until the contact the washer, then back them off a half turn.
427HISS
You sound like me,.....FRICKEN NUT'S ! :eyecrazy:
I can be kinda of a perfectionist.
With searching, for some reason with my wifes tablet, when I click in the search box, my words disapears.
427HISS
For some reason with my wifes tablet, when I click in the search box, my words disapears.
johninct
1" thick rubber. I did buy the ones specifically for my compressor but did not use them. They looked like cork board, so I went with 1" rubber.
Modern Garage
Southern Minnesota
I installed my compressor about ten years ago withthe square cork with rubber face pads. They collapsed to about a quarter of their original thickness in less than a year so I'm guessing they don't do much to isolate but the big bertha has never moved a millimeter since I dropped it there.
Joe
427HISS
Your tank can crack and leak if you bolt it rigidly to concrete without rubber. Why do mine not walk but OP does?
Mine does the waltz around the garage. I let it lead by my feet on top of it. :p
It was a perody buddy. lol :lol_hitti
With nothing between the concrete floor and the feet, it's noisy.
notlob
norcal
Even though they are considerably more expensive, I think I'd buy these instead of the cork pads :
https://www.supplyhouse.com/DiversiTech-MP-2E-EVA-Anti-Vibration-Pad-2-x-2-x-7-8
Kenskip1
Missouri
I borrowed a few pieces of cedar shake siding from my neighbors house. These are tapered and work like a charm.Ken
