OK, no easy way to say this and I'm just gonna 'fess up. I'm in the middle of framing my basement and opted to build the frames on the floor and then lift them up.
I am framing for 16" OC and made each section at a time, double and triple checking each stud would be 16" OC and be perfectly straight up and down.
However, what I didn't account for is where each section mates up with the next. During my planning, I designed it so that each section wouldn't just have a 2x4 on the end, but would carry over the 16" OC pattern. What I actually did was forget all about my planning and in my excitement to use my new cordless DeWalt framing nailer, was just frame to the measurements. To make matters even worse, I even stood up each section and attached them to the joists and the floor so they are now set.
The problem is this - where two sections meet, they have 2x4's right next to each other. When i started drywalling, I immediately realized my mistake because over time, the edge of a sheet of drywall wouldn't land in the center of a stud, but a little past it. I started off just by sistering another 2x4 to a stud so I'd have a nailing edge, but now that I'm a few sheets of drywall in, they're progressively getting further and further away from a stud and sistering just isn't an option.
To remedy this, what are your thoughts on adding pieces of 2x4 horizontally between the studs where the edge of the drywall lands and then using that as a nailing edge? I would add a horizontal piece every 12" and nail them in with 2 nails from either side of the supporting stud.
I thought about adding another stud vertically to get the nailing edge, but I'm having a real hard time stopping the stud from moving from my measurement when I nail it in. I can brace the bottom with my boot (carefully) so it doesn't shift but the top is too hard.
and yes! I know I should have accounted for the 16" measurements but the d*mn DeWalt nailer was just too fun
