Strouty
Please post the part number of the vessel tool, looks like it could be useful. Thanks!
I think it's the model Vessel Megadora 970 cr-300Please post the part number of the vessel tool, looks like it could be useful. Thanks!
Very nice!
What is the diameter of the chuck/ holder on the 6310?
Thanks
the black collar of the chuck is 14.3 mm wide and 17.7 mm long.
Other dimensions:
Overall length of tool 21.5 cm
total length of shaft (including chuck) 10.3 cm
Available through i-Tools, at least since 2009, when I bought my pair.
I just used the bent nose pair a couple weeks ago. They are decent quality pliers, especially for the price.
View media item 81328
Although the TX-10 was definitely a big improvement over my other (magnet only) multibit driver handles and ratcheting screwdrivers, the TD-6310HX takes it to the next level. When you lock the bit into the chuck, there is absolutely no play. It feels like the tip is one continuous piece of metal with the shaft, just like a "real" screwdriver. Operation of the collar is also more positive and intuitive. The TD-6310HX has replaced the TX-10 in my toolbox. Love it!
that wobble driver looks interesting! can i ask how you like it?
Here's their URL: https://global.rakuten.com/en/store/i-tools/
I ordered it from JDV Products
Vessel pry tool
https://www.vesseltools.com/handtools/screwdrivers/megadora/970-cr-300-detail
I own it as well
It appears they no longer make that model.![]()
I have the TX - 10 myself. There are better bit drivers out there, but it's pretty good. Really good for the money in fact. Mine lives in my woodworking box, specifically for using on the crappier woodscrews.
I really like the look of that TD-6310HX. That handle style is called 'Crystalline'.
Unfortunately, none of the folks who stock Vessal drivers in the U.K. bother to keep the Crystalline range. Shame, as I think it's one of their best lines!
Today's deliveries from Amazon.
https://www.amazon.co.jp/gp/product/B002PK0JOK/Have you got a link to the Hyper Long pliers on Amazon? I couldn't find them on USA or JP.
$65 with free shipping?Thanks!
Ordered the Hyper long straight and the bent thin nose slip joint pliers. Price including shipping was best through amazon jp for the two.
Seth
Latest Tools for Thought video:
What inspired the Japanese to create a series of pliers with a built-in screw-extraction feature? What's with the recent craze with this type of pliers? This video will touch on this subject and offer some background and history behind this seemingly recent phenomenon.
The first name that comes my mind when I think of screw-extraction pliers is 3.Peaks. 3.Peaks is a pliers manufacture in Northern Japan that produces specialist and precision cutting/grabbing pliers.
Engineer is a company that specializes in procuring tools that meet Engineer's requirements and provides them to the electronics industry and associated trades. The "Nejisaurus/Vampliers" pliers are produced to Engineer's own specs/patented design by one of the few pliers manufacturers currently operating in Northern Japan, then inspected/packaged by Engineer.
Thanks for another excellent video!Latest Tools for Thought video:
I think the same that 3peaks makes most Hozan pliers, possibly their top ones!Thanks for another excellent video!
The 3.Peaks DS-150TZ seem nearly the same as these Hozan P-213B, and as a pair of 3.Peaks wire cutters I posted earlier also had almost identical Hozan equivalents, I wonder if 3.Peaks manufactures many Hozan pliers.
Thanks for the video and the information.Latest Tools for Thought video:
[video link deleted]
Interesting info, thank you.Sanwa EM7000 FET Multitester . . .
Sanwa, the Japanese electronics company is not to be confused with Sunwa, a Chinese (PRC) company that makes dirt cheap VOM multimeters found nearly everwhere that sells dirt cheap multimeters in North America. Oh, those clever Chinese and their product names that look and sound so similar to other companies whose high quality products sell for about 10x the price.
Sanwa is better known in North America for its radio controlled hobby control electronics. They do not market their electrical measuring instruments here. They have two entire lines of multimeters/multitesters, one analog like this one and the other digital. Their multimeter lines are very well known in the Pacific Rim, including the Philippines. I've seen some presence in Europe but don't know how widespread that is. Analog meters are still in demand and have a number of applications in which digital meters do not perform very well.
Sanwa calls the EM7000 a FET multitester, not a multimeter which differentiates it from the standard VOM multimeter. FET is the acronym for Field Effect Transistor, which has the very high impedance and other characteristics very similar to a triode vacuum tube. A FET is commonly used as a voltage amplifier just like vacuum tube were, versus the PNP and NPN junction transistors being used as current amplifiers. Several decades ago it was much easier to find FET multitesters as a number of companies made them. Even Radio Shack had one under the Micronta name. Today, this is about the only one on the market.
What makes a FET multimeter special? It is the battery powered solid state equivalent of a VTVM (Vacuum Tube Volt Meter), which graced the bench of anyone doing serious electronics work through the 1970's. The VTVM contained a triode vacuum tube, hence its name. My father had a very nice Heathkit VTVM, which I used in my high school years before moving out shortly after graduation. You'll note it has a power switch, not something found on analog VOMs. Its internal electronics, which use a FET, must be powered up. It has an internal 9 VDC battery of the common type found in battery powered household smoke alarms.
The reason for a VTVM and now a FET multitester:
A VOM is rated (among other specs) for how much internal resistance it presents in ohms per volt. To measure voltage, it must insert itself into the circuit using passive resistors (which ones depend on meter range setting) and create a voltage drop that moves a very sensitive meter. On many circuits the meter resistance is minuscule small compared to the circuit impedance and creating a minuscule voltage drop that won't make a measurable difference in 3 significant digit measurements. On extremely high impedance circuits, however, the VOM resistance start to become significant compared to the circuit impedance, resulting in a measurement that is lower than what it is without the meter inserted into the circuit. A VTVM or FET multimeter uses a massively higher resistance (ohms per volt) compared to a VOM. The VTVM uses a triode vacuum tube, or in its solid state equivalent, a FET to amplify the extremely small voltage to one that will drive the meter. The result is substantially greater accuracy in voltage measurements on very high impedance circuits.
The following web page has an excellent explanation about the impact of a test meter on the circuit being measured:
Chapter 8: Voltmeter Impact on a Measured Circuit
The reason for an analog meter:
Shortly after hand held LCD display digital meters became all the rage in the 1980's, those who were doing circuit alignments pitched the new digital meters and went beck to their analog. A digital meter works by sampling a voltage a number of times per second and updating the display a number of times per second. It's fast enough you normally don't see any flickering. However, when adjusting a trimmer capacitor or resistor (aka potentiometer) in a circuit calibration or alignment, the numbers displayed on a digital meter starts to jump around and one must significantly slow the adjustment or keep stopping to let the display settle on a value. An analog meter needle is damped and will swing smoothly as the adjustment is made. Much, much easier to follow visually than a numeric display with the numbers flickering between different values. The blue scale with the zero in the middle is a "null" scale. The meter can be set up after it's turned on so that the needle is centered for DC voltage or current measurements. The range settings for it are in matching blue around the switch positions for DC voltage and current range settings. One example of its use (and there are others) is in logic circuitry that has logic voltages above and below ground. The alternative would be a reversing switch like that found on a Triplett 310-C VOM. This is much more convenient than flipping a switch or the more cumbersome switching which probe is attached to circuit neutral or ground. Some alignments require centering on a null, or zero DC voltage or current flow. The null scale and setting the meter up for it allows that as well and allows great sensitivity. In addition, extreme precision with theoretically zero impact on a circuit can be set up with a null measurement meter. The tail end of the web page above shows how a meter with a null measurement capability can be set up with some additional equipment and components to do just that.
For those that wished they still had a VTVM for its special measurement characteristics, Sanwa is the only company I found currently making a battery powered solid state FET multitester. Much more portable than the classic VTVM which is much bigger and requires the power mains from a wall outlet to power its triode vacuum tube.
John
Are they used nowadays commercially? How they compare let's say with the latest high grade ones like Fluke?
