Miter saw
Floridaboy
What saw do any of you use for cutting laminate floor?
KSB
Eastern Ontario, Canada
I’ve got a Mastercraft sliding miter saw that works great.
If the planks aren’t that wide you might get by without a sliding saw but I usually find that it is needed.
I was using a Dewalt 12” today, nice saw but my Mastercraft does the same job.
catron44
CT
I've used a 12 in dewalt slider and non slider. I know some guys use a Makita 8 in slider because it's much lighter.
No matter what saw, get a blade designed for laminate flooring.
Sent from my SM-G955U using Tapatalk
engineer2
Chicago burbs
Makita 18 V cordless circular saw and an angle square as a guide.
Makita 18 V jigsaw for notches.
Since the cut ends are covered by trim, it doesn't need to be perfect.
F
Floridaboy
AZ Pete
Central Arizona
I used a DeWalt 10" miter saw. Use a cheap carbide blade, toss it when you are done...the blade, not the saw. I like the idea of the $50 flooring cutter, but it has no other use, so sell it when you are done
Parrothead
Earth
Honestly, in this case it doesn't matter.
You're making a 90 degree cut, 99.9% of the time. As long as you can get it square anything with a big enough blade to cut the material will work.
Same thing for wood siding.
Make sure to get a blade for laminate flooring and have at it.
Here you go...$95 after coupon and sell it on Craigslist when you're done. Cheaper than renting. Or use it as an excuse to buy a better one for other more precise projects.
https://www.harborfreight.com/10-in-sliding-compound-miter-saw-61971.html
4phant
You can check Hitachi C10FCE2, it is giving the best performance to me.
psychoclaw84
Valley of the Sun
1st of all a Very good Blade is needed, use the Freud Circular Blades designated for Laminate use and Jig Saw blades designated for laminate use.
- Bosch GCM12SD 12 In. Dual-Bevel Glide Miter Saw: For cross and angle cuts.
- Bosch JS365 Top-Handle Jig Saw, small cuts.
- Dewalt DWE7499GD 10" JOBSITE TABLE SAW: Rip cuts
:thumbup:
6PTsocket
I haven't done any laminate but I would imagine a task specific saw would be best in this case.
Also, as someone else said, get the correct blade.
What is a task specific saw? A miter saw or sliding saw is made for cross cuts. Any saw with a big enough blade to cut the widest anticipated board in one shot is big enough. He will be fine with any reputable brand, Bosch, Milwaukee, Makita or DeWalt and probably a few others. If he plans to use the saw for other things then he has to allow for that. In any case a blade matched to the type of flooring is needed for clean cuts. That might be a laminate blade or fine tooth cross cut. You can't go wrong with Forrest.
F
Floridaboy
This is what I’ll be cutting this weekend and putting down. Ended up getting a 7 1/4 sliding miter saw from Lowe’s (under 90$) and picked up some 84 tooth blades we will see
Milton Shaw
Skill makes a dedicated flooring saw that is designed to rip and crosscut and is designed to be down on the floor with you while you work. Its about $160 on Amazon and seems to be well made. I have one but have not used it yet for flooring. I found mine at a tool outlet and paid about $100 for it. Its much easier to move than a 12" sliding miter saw and like I say is designed to move along the floor with you as you trim around object. Prevents a lot of up and down as you are working the floor.
F
Floridaboy
Gonna put it through the test tomorrow.
F
Floridaboy
I would say this saw is a dream come true. I’ve use to put flooring and all new baseboards and shoe molding. I think the wife wants crown molding next we will see.
Parrothead
Earth
Good for you! Now we need pictures of the completed projects! Also glad you're enjoying the work!
