Air Hose Size
HaroRider
New York
Hey all, so I am curious what you guys think. I run my home shop with a 3/8" hose and mostly use 3/8" or 1/2" impacts when my Milwaukee has a hard time taking off a fastener or when it is dead.
I recently just picked up a 3/4" Earthquake. I have an extra 1/2" hose, should I switch everything over to 1/2" hose? Will this cause a negative effect on my tools since my tank is rather small? ~40 gallons. (Keep compressor running way too much?)
Or should I just keep everything 3/8? Will this greatly reduce the effectiveness of the 3/4" gun? Just trying to get some ideas on what to do.
I could just use the 1/2" hose only for the 3/4" gun but that may get annoying after awhile, even though I am only going to use it on occasion.
plinker
Northern Wi
Buy a 1/2" hose (look on ebay for a Speedaire branded Flexzilla, they were around 25$) and 3/8 body couplers/plugs for it. The make or buy a short 6'-10' whip hose that connects to the 1/2" hose so you can use your other air tools with it. Or have two hoses set up at the same time.
BlueBomber
Outside Boston, MA
I have a 3/8" coupler on the end of my hose. I assembled a 3/8" male to 1/4" female adapter for all my other tools and take the adapter off when I need the larger fitting for my bigger impact gun. You could apply the same principle or a whip hose as said above.
Packard V8
Spokane, WA
Yes, general consensus is a 3/4" gun requires a 1/2" hose. That's if one is servicing big rigs, busting a hundred lugs more than 100' from a compressor.
No, the 1/2" is not an absolute must for general home shop use. I've run a 3/4" Earthquake successfully on 3/8" line. Once I took it to a friend's project and it operated on a short 1/4" line.
Bottom line - it depends on compressor pressure and volume, length of hose, diameter of smallest fitting in the system and what size/how many nuts one is busting.
It should also be noted OP has only a 40-gallon tank. How many applications before pressure drops and the diameter of the hose is immaterial?
jack vines
Pontiac787
New Hampshire
For practical purposes would you see a noticeable difference in performance between a 25’ 3/8 hose and a 50’ 3/8 hose all other things being equal?
sberry
Brethren, Michigan
Absolutely if the volume is high enough. On a heavy 1/2 gun losses can be near a pound a foot. Have to run 140 to get 90 at the gun thru 50 ft of 3/8. This is why 2 stage is for running tools, so it can be turned up to contemplate for loss.
25 ft has 1/2 the loss of 50 and 1/2 has half the loss of 3/8 at these volumes, a bit over 20 cfm or so, I don't remember the exact math right now.
A 1/2 does help a 1/2 gun also,,, it's a matter of being suffecient. If it's working with 3/8 then it's working, but with single stage if it's not it can be helped with larger hose with marginal compressor.
sberry
Brethren, Michigan
This is a compelling reason to start with a better comp, don't have to fart with everything downstream forever to make up for loss, smaller piping and hoses can be used. Also makes up for long runs.
theoldwizard1
SE MI
The real issue is, what is the pressure at the END OF THE HOSE when the tool is running ! The only way to know is make up a tee with a pressure gauge. Use the same quick connect (or threaded *******) and a whip to connect it to your gun.
It could be as simple as turning up the pressure at the regulator.
sberry
Brethren, Michigan
Yes, there is a lot of focus on the connectors, they only hurt a little. Main thing,,, is it working?
Leveleer
Superior/Duluth
I just measured the pressure drop across a 25 foot long 3/8 diameter Flexilla hose.
At 30 SCFM the pressure drop is 18 PSI.
However, half of that is because of the long 1/4 bore in the 1/4 NPT end fittings.
Leveleer
Superior/Duluth
How did you measure the cfm? That is a bit better than I thought it would be.
Orifice plate method.
I had an extra hose of the same type with a stripped aluminum 1/4-18 fitting so I cut the fittings off both ends of the hose and replaced them with 5/8 compression fittings and tested this hose.
It tested at around 15 PSI drop vs 18 for the other hose.
