What do you use an air hammer for?
GeorgiaHybrid
Extreme NW Georgia
Removing exhaust systems, taking out the rivets in a riveted ball joint, used with a "U" fork to pop loose tie rod ends, ball joints, etc., punching out bolts or rivets that have had the head cut or burned off, cutting panels with a panel cutter (faster than anything else if the chisel is sharp) and a lot more.
Packard V8
Spokane, WA
Besides funding the audiologist's retirement plan?
All that mentioned above plus driving valve guides and pin bushings in and out.
thnx, jack vines
bmxr4life87
Bixby Oklahoma
All the above plus removing fan clutches with an
18" long 3/4 wide chiesel and also in places where you just can't get a good swing with a hammer and when you have to destroy a bushing to get it out normally an air hammer will speed things right along
GDA
Dallas, Texas
So far I've used mine for -
Removing old suspension bushings on the bench
Removing ball joints and disassembly of front suspension parts (only when not reusing the part)
Busting up a couple small sections of concrete walkway in the backyard
Mickey O
Chicago, IL
Some of the stuff above, cutting sheet metal and chipping concrete. I'm just getting ready to sell my to old ones and replace them with a NOS one I have.
jeepnut24
Morrison CO
I will be using mine to remove most of the rusty quarter panel on my project car.
I wish I had the room for a plannishing hammer that used one, but not enough floor space.
Rnz520
Culpeper, VA
add to that removing an International oil pan thats held on with International gray RTV (Concrete), my coworked had to ruin a pan to get it off, it was pretty awful.
C
Cobra4B
Virginia Beach, VA
Gotcha... never used one before... have a C-man free-bee in my box that I've never touched. If it's anything like the free air gun and ratchet it's only good for a paper weight.
fatfillup
Finksburg, Md
I have a hammer bit (looks just like the face of a ball pien hammer) that we use all the time to shock rusted bolts or parts loose. In the case of bolts if you can rap the area where the bolt is screwed into, you can almost always get it loose without breaking the bolt off. Same applies to rusted parts or pulleys on shafts. Bought mine at Napa and it was under $20.
Also use the chisel to shear off bolts where the head is just rusted to nothing.
Noise is definitely an issue so wear hearing protection if you are using it alot.
crewchief888
NW indiana
i have an old CP that i use to clean slag off welds and shake loose rust and dried mud from under my wheeling truck.
i have a snapon that i use to pop tie rods and ball joints, and drive out large roll pins
i stopped trying to rip sheet metal with an air hammer, i've broken more panel cutting bits than i can count over the years :willy_nil
:beer:
Charles (in GA)
50 mi south of Atlanta
De-heading a 55 gal barrel.
Getting things apart that are stuck.
Ball joint pickle fork.
Cutting ball joint rivets (after drilling a small hole thru them)
I used it on my 2.3L Ranger to get out a stuck O2 sensor. Had to remove the starter to get the gun and a chisel bit in place, but caught one of the corners of the hex and went to town on it, and it came out. Nothing else would budge it.
Charles
Hal
Vermont
With a hammer head, driving the caps out of u-joints. With a chisel, splitting nuts, exhaust pipes and mufflers. With a punch, driving out stuck bolts and rivets.
trackwelder
n.y
Not the safest but I use my for rusted locking rings on fuel tanks.
I wondering if they make brass or bronze chisels?
Joe69
Muncie, Indiana
I do the same thing. Over the years, my air hammer(with a hammer head bit) has become one of my favorite tools.
Joe
Paul_NJ
New Jersey
It was the only way that worked getting the *&$@#% rusted-in wheel bearings out of my 4WD Yukon
C
Cobra4B
Virginia Beach, VA
To use it on a ball joint do you just put a chissel attachmemt on it and drive it out via the main shaft head?
I was at Northern tool last night and saw an air chissel set... makes more sense now.
GDA
Dallas, Texas
C
Cobra4B
Virginia Beach, VA
I've found that pickle forks like to booger up the rubber boots on my balljoints on my Corvette. Maybe they make slimmer ones than what I've had access to.
Charles (in GA)
As already noted, this is for destroying the joint and boot, when you are replacing them, gets them apart fast however. If you need to save the joint and boot you need a screwjack type of press that will get them apart without damage.
Charles
C
Cobra4B
Virginia Beach, VA
Charles
Yep... you hit the nail on the head. If I have to replace the hubs I go get that screw type seperator and it works like a charm. If the hub wears out fast enought a whack with a hammer on a well placed 2x4 works too :lol_hitti
Just trying to learn how to better take advantage of my air tools.
brockstar
Cincinnati
Its my tool of last resort - somefing's gonna get f'd up when it gets used..
I've used them to remove torsion bars and even rusted on gas charged hood supports..
Loud, brutal, obnoxious, but effective.
C
Cobra4B
Virginia Beach, VA
I'm in the middle of a kitchen remodel and have some floor tile to take up... anyone use one for that? I think it'd make quick work of it and my compressor/hose plenty long that I can get it into my foyer area w/o having to move anything.
Paul_NJ
New Jersey
Make sure you know what you've got first. I used an air gun with flat chisel for peeling up old linoleum style floor covering from a concrete floor at my old farmhouse. If the flooring goes back to the 50's (before vinyl), as mine did, some of it is impregnated asbestos fiber, and you have to take precaution to prevent the asbestos from becoming airborn. There are recognized procedures you can find online, but basically they involve mopping first with a soapy water solution to keep things wet.
