Cobra4B
Just curious... what are some common uses for an air hammer/chissel in an auto shop?
-Brian
-Brian
Installing dents![]()
Hmm...
I always thought they were for installing smilies.
Hmm...
How? Haveing a hard time visualizing how you'd do that.
Gotcha... never used one before... have a C-man free-bee in my box that I've never touched. If it's anything like the free air gun and ratchet it's only good for a paper weight.
I have a hammer bit (looks just like the face of a ball pien hammer) that we use all the time to shock rusted bolts or parts loose. In the case of bolts if you can rap the area where the bolt is screwed into, you can almost always get it loose without breaking the bolt off. Same applies to rusted parts or pulleys on shafts.
Not the safest but I use my for rusted locking rings on fuel tanks.
I wondering if they make brass or bronze chisels?
To use it on a ball joint do you just put a chissel attachmemt on it and drive it out via the main shaft head?
I was at Northern tool last night and saw an air chissel set... makes more sense now.
I've found that pickle forks like to booger up the rubber boots on my balljoints on my Corvette. Maybe they make slimmer ones than what I've had access to.
Yep... you hit the nail on the head. If I have to replace the hubs I go get that screw type seperator and it works like a charm. If the hub wears out fast enought a whack with a hammer on a well placed 2x4 works tooAs already noted, this is for destroying the joint and boot, when you are replacing them, gets them apart fast however. If you need to save the joint and boot you need a screwjack type of press that will get them apart without damage.
Charles
Just trying to learn how to better take advantage of my air tools.
I'm in the middle of a kitchen remodel and have some floor tile to take up... anyone use one for that? I think it'd make quick work of it and my compressor/hose plenty long that I can get it into my foyer area w/o having to move anything.
