ZMotorsports Shop Projects 2.0
Z
zmotorsports
Northern Utah
Mike, another great job. Is that black (looks like nylon/canvas?) wrapped up on the tow bar a rock shield of some kind? I have never flat towed anything so I learning and filing this away in my memory for later use!
Sent from my iPad using Tapatalk Pro
Thanks Duke. Yes, the mesh that is rolled up is fastened to the stinger of the towbar. It is also made by Roadmaster and marketed as their Tow Defender. It is designed to help with rock chips. I towed my first several Jeeps well over 100k miles combined and can count on one hand and have fingers left over how many actual rock chips I got.
This Jeep has been my Achilles heel of rock chips so I tried the mesh a few years ago and it helped but didn't eliminate them totally. I finally found the source and it turned out to be the Jeep rather than the coach flipping up rocks. I remedied that a few years ago but seeing as how I want as much protection as possible I continue to run the Tow Defender even though with my experience it actually benefits quite marginally.
Thanks for following along Duke. Your place is sure coming along nicely. I'm happy for ya bud.
Duker
Livingston, TX
Thanks Duke. Yes, the mess that is rolled up is fastened to the stinger of the towbar. It is also made by Roadmaster and marketed as their Tow Defender. It is designed to help with rock chips. I towed my first several Jeeps well over 100k miles combined and can count on one hand and have fingers left over how many actual rock chips I got.
This Jeep has been my Achilles heel of rock chips so I tried the mess a few years ago and it helped but didn't eliminate them totally. I finally found the source and it turned out to be the Jeep rather than the coach flipping up rocks. I remedied that a few years ago but seeing as how I want as much protection as possible I continue to run the Tow Defender even though with my experience it actually benefits quite marginally.
Thanks Mike, I keep trying to talk my wife into the possibility of travel via trailer or motorhome but she hasn’t warmed up to the possibility.......yet.....
I appreciate the comments on my shop. While it is coming along the pace is way to slow for my liking. Your thread keeps the fire lit under my a$$ to keep moving forward as I see how much you are enjoying yours.
Z
zmotorsports
Northern Utah
I pulled the Jeep in the shop tonight to start my next upgrade or mod.
The JK’s seem to have a pretty anemic steering gearbox, specifically the sector shaft. The sector shafts have been known to shear off when running larger than OEM tires/wheels and getting them bound up when off-road. That is pretty much enough to ruin your day of fun.
For the ultimate in strength and steering ability off-road a full hydraulic system is the cats meow. Seeing as how full-hydro is not DOT approved the next best option and a very common option at that is the hydro-assist setup. This design taps into the power steering gearbox and feeds hydraulic pressure to a double acting cylinder that has one end connected to the tie rod assembly and the other end to a bracket on the axle. This is a very good setup for those running large tires/wheels and frequently engage the front lockers and still allows very good steering. It is also less stressful on the gearbox and frame as it splits the forces between the gearbox itself and the hydraulic cylinder on the axle, actually placing more force right at the axle and tie rod and less on the gearbox. In my personal opinion this is probably the best setup for tires over 37” in diameter who wheel their rigs hard. However, also In my opinion this is the most expensive and has multiple potential failure points, as in hydraulic lines although failures are not very common.
The next setup is PSC’s new upgraded steering box. PSC advertises this setup for up to 37” tires but again in my opinion 37’s are on the bubble depending on how you wheel and if your front axle is locked or not, although I have heard of a few people even running 40’s with just the upgraded gearbox.
I am only running 35” tires and seriously doubt I will ever step up to 37’s so I wanted something that mainly addressed the weak sector shaft but if I can get a bit better steering performance at the same time it’s a bonus. For my situation I feel this PSC upgraded gearbox will be the best bang for the buck and give me exactly what I am looking for.
To compare spec’s, the difference between an OEM Jeep JK/JKU steering gearbox and the PSC are as follows; the OEM has a 70mm piston and the PSC has an 80mm piston. The OEM sector shaft is a scant 35mm in diameter vs the PSC’s 45mm sector shaft, that is 30% larger. Basically the PSC gearbox closely resembles the Dodge 2500/3500 steering gearbox.
So there is the “why” behind my upgrade now let’s get to the actual upgrade. One more upgrade I thought I would do while I have the system open and fluid drained is to add a power steering cooler to the return line. I purchased a Derale 12” oil cooler a few years ago for a different project but never used it. I will be looking for a place to mount that while I’m under the Jeep.
Here is the PSC Big Bore XD that will reside under my 2011 Jeep Wrangler
Before spinning any wrenches, I used my oil evacuation tank and pulled as much fluid out of the reservoir that I could. I figured this would be less “potential” fluid that would end up on my floor.
I removed my JKS steering gearbox support system then removed the steering column connection (where I’m pointing) then I can focus on removing the actual gearbox.
Here are the two power steering lines that need to be removed. The one I am pointing to is the pressure line.
I have collected a pretty good assortment of plastic caps and plugs over the years for situations like this. These are o-ring fittings so I capped each one after removing from the gearbox to minimize the mess and oil running down the frame.
OEM gearbox out and on the bench next to the new PSC unit ready to go under the Jeep.
Before closing up the shop for the night I cut the mounting block off of the frame from my JKS gearbox support as well as a tab from beefed up trac bar bracket. I blended the ground weld and sprayed some Eastwood Extreme chassis paint on the area to allow it to dry overnight.
Today was so nice I was able to work in the shop with the roll up doors open for the first day of the year. Freakin’ awesome!
Thanks for looking.
nbruno
For the ultimate in strength and steering ability off-road a full hydraulic system is the cats meow. Seeing as how full-hydro is not DOT approved the next best option and a very common option at that is the hydro-assist setup. This design taps into the power steering gearbox and feeds hydraulic pressure to a cylinder that has one end connected to the tie rod assembly and the other end to a bracket on the axle. This is a very good setup for those running large tires/wheels and frequently engage the front lockers and still allows very good steering. It is also less stressful on the gearbox and frame as it splits the forces between the gearbox itself and the hydraulic cylinder on the axle, actually placing more force right at the axle and tie rod and less on the gearbox. In my personal opinion this is probably the best setup for tires over 37” in diameter who wheel their rigs hard. However, also In my opinion this is the most expensive and has multiple potential failure points, as in hydraulic lines although failures are not very common.
So there is the “why” behind my upgrade now let’s get to the actual upgrade. One more upgrade I thought I would do while I have the system open and fluid drained is to add a power steering cooler to the return line. I purchased a Derale 15” oil cooler a few years ago for a different project but never used it. I will be looking for a place to mount that while I’m under the Jeep.
OEM gearbox our and on the bench next to the new PSC unit ready to go under the Jeep.
Thanks for looking.
Mike, I wish I had the inclination to document my work as well as you do. Always fun to follow along.
Z
zmotorsports
Northern Utah
Thanks Nate. I hope to add this installation as another video to my channel as well as soon as I finish it up.
Thanks for following along.
Z
zmotorsports
Northern Utah
I finished up the PSC gearbox installation tonight and started coming up with a plan for mounting the Derale oil cooler.
I think I have a plan for mounting the power steering cooler.
Thanks for looking.
Z
zmotorsports
Northern Utah
I only had about an hour to work in the shop tonight so I fabbed up the mounting brackets for my power steering oil cooler.
Here’s what I started with, a 3” long piece of 2.250” diameter x .120” wall tubing that I cut in half lengthwise to saddle over the 2” diameter cross member and two pieces of 1/4” flat strap.
Saddles welded to tabs after drilling and tapping the tabs to match the coolers bolt pattern.
Mounted to the oil cooler.
Oil cooler mocked into position.
Bead blasted, painted and ready for installation.
Thanks for looking.
Z
zmotorsports
Northern Utah
I finished up my PSC Big Bore XDII power steering gearbox and steering cooler tonight. I test drove it and I am very pleased with the results after only a short 16-18 mile drive. Tomorrow our Jeep club is going on our monthly club run so I’ll see how it does. The run won’t be technical but I should get a decent feel for it being aired down.
Oil cooler is fastened in place, that’s not going anywhere.
I reinstalled the engine coolant reservoir back into place and here you can see the gearbox nestled down between the engine coolant reservoir and windshield washer fluid reservoir.
Another shot of the oil cooler fastened to the crossmember.
Shot of my Jeep after the road test and cleaning up mess/putting tools away.
The video of the installation is uploaded to my YouTube channel for anyone who wants to check it out.
Thanks for looking.
NASTYZEN
St-Colomban,Que. Canada
My oldest Son just got a jeep like yours. I have to make sure not to show him this thread and give him all kinds of expensive idea's.:)
Nice job on the steering box install. Hope you don't have issues with other things in the system down the line from it that haven't been upgraded..
Z
zmotorsports
Northern Utah
Thanks Claude. The whole Jeep thing is quite addictive. JEEP, Just Empty Every Pocket.:willy_nil
As for everything downstream of my steering box, that has already been upgraded. Trac bar, drag link, tie rod, tie rod ends, axle, pretty much everything and the gearbox was the last component so I hope to have built in a nice safety margin for reliability.
Tell you son I hope he enjoys his Jeep and with your abilities to help him, I'm sure he will build some cool components for it.:thumbup:
Thanks for stopping by and checking on things Claude, always a pleasure to have you check out my projects.
Z
zmotorsports
Northern Utah
While I had the Jeep in the shop on the lift I thought I would address one “potential” issue. On an RV site a while back there was a thread where a guy had his Jeep JK come loose from his coach due to a towbar connection point failure.
On the underside of the Jeep JK frame is a sub-frame box welded perpendicular to the frame rail at the front. This box is constructed of 10-gauge steel and where the manufacturer mounted a plastic skid. This sub-frame is what I connected my tow bar crossmember to that I fabricated about 7 years ago. When I fabricated my front winch bumper I tied it directly into the frame rails where the winch would pull as well as my recovery points. At that time I also welded a couple of tabs connecting those sub-frame boxes to the frame rails. I routinely inspect my Jeep’s tow bar connection points, crossmember, safety chain connection points as well as hitch on the coach to ensure safety and I have especially been keeping an eye on it since seeing the failure on the internet. If memory serves he was running a Blue Ox towbar mount.
While I was looking things over with the Jeep on the lift last week I came up with a plan to tie my tow bar crossmember directly to the frame just to ensure I never have a similar issue.
Cutting a couple pieces of 1/4” plate.
Doing layout on materials.
I had to put a slight bend in the plate to allow enough room for the fasteners to clear.
I then had to get a bit creative and clamp the pieces to an angle plate while tack welding the pieces together.
Mocked the components up for fitment.
While mocking up the parts I realized I needed to remove a very small amount for clearance. Rather than grinding the small amount off I opted to run the edge through the vertical bandsaw. I love this Birmingham vertical bandsaw and how easily it is to control and remove such small amounts.
Here I removed a sliver of .015”, plus the .035" wide blade for a total of .040" off of the piece.
I’ve mentioned this before but I subscribe to the theory of the 7 P’s; Proper Prior Planning Prevents Piss Poor Performance. When I built my shop I made sure to put several 50-amp receptacles around the shop so I could merely roll my welders around and plug it to different areas without having to run extension cords, so glad I did. I moved my welder over to the other side of the shop and plugged in so I could tack the brackets together while bolted in place on the Jeep frame.
I then moved back to the fabrication table and finished welding the brackets together.
I beadblasted and painted the brackets before final installation.
One thing I did during mock up was to insert some .045” shims under the brackets at the front frame points so upon final assembly with the shims removed and tightened the brackets would preload a small amount tying the towbar crossmember to the frame.
Thanks for looking.
nbruno
Here I removed a sliver of .015”.
Thanks for looking.
Smart move Mike. That crash bar, if not tied into the bumper is a definite weak link as a tow point. Once again, nice work.
Z
zmotorsports
Northern Utah
I have my cousin’s ‘97 TJ in the shop building him a rear bumper and tire carrier.
He asked me to fabricate one for his Jeep in the fall of 2016 but we were hot in the middle of house hunting and I was not taking on any more work in my shop at the time.
His Jeep bumper was on my white board since my shop completion and every time he comes over the first thing he does is walks to the white board to see where it’s at in the lineup.
I called him last week and told him I was finally ready for him to bring me his Jeep seeing as how he has patiently waited for me to get my shop up and running.
OEM bumper cover removed.
Frame mounts in place.
I usually start with plate and build out the center section but I had a piece of 2”x5”x.188” U-channel kicking around that would be perfect for this.
Prior to welding the U-channel to the frame mounts I opted to mount the D-ring tabs. I like to tie them in directly in line and to the frame mounts so I cut a 3/4” wide by 1.5” long opening and welded them from the back side as well as the outside. I also had to cut two small slits to clear the hitch mounting brackets.
Ready to weld through the channel after tack welding the D-ring tab on.
D-ring tab welded from the outside afterwards.
Frame mounts welded to the U-channel.
Once the D-ring tabs and frame mounts are welded I needed to add a 1” filler piece to the top to fill the gap between the bumper and body.
Weld blended and bumper bolted into position.
I then made some cardboard templates for the outer ears of the bumper and transferred them to some .125” plate. Here I have them nested and ready to cut.
Outer ears tack welded into place. The gap between the upper and lower is exactly 3” due to tapering the bottom upwards.
Next task will be to make some cardboard templates of the areas to fill in between the upper and lowers, then transfer to steel plate and weld into place. After the bumper itself is completed I will move on to the swing away tire carrier.
Thanks for looking.
Z
zmotorsports
Northern Utah
Looks like another fun project.
Yeah, kind of a fun one. I’ve built a few bumpers for JK’s and a couple front bumpers for ZJ’s but this is my first TJ rear bumper.
It’s always fun to do something new rather than the same thing over and over.
Thanks for stopping by my projects thread and checking out what I’m working on.
I just finished up a swing away bumper / carrier on an XJ for a friend. He wanted it down and dirty like his Jeep, lol.
The frame was not rigid enough to use those D rings on the bumper. I used one of those axle spindle kits for the pivot swing. Are you using a kit or designing your own?
LXCam
Very nice as always Mike. I'm almost finished with installing air conditioning and a 4" lift on a tj. Today will get those two projects at 100% and get me going on the winch install that needs to be one-off'd like your bumper. So now I'm in line with the same question for the D rings, fabbed or store bought? And if you bought those, where'd ya get them :)
Keep up the great work and thanks, Cam
Z
zmotorsports
Northern Utah
Did you purchase those D ring tabs or make them?
They look extremely beefy.
I was wondering the same thing. They look like they were water jet cut.
Very nice as always Mike. I'm almost finished with installing air conditioning and a 4" lift on a tj. Today will get those two projects at 100% and get me going on the winch install that needs to be one-off'd like your bumper. So now I'm in line with the same question for the D rings, fabbed or store bought? And if you bought those, where'd ya get them [emoji4]
Thanks for the comments guys.
The D-ring tabs are purchased components as is the spindle mount for the swing away tire carrier. I usually purchase those items from either AtoZ fabrication or Ruffstuff Specialties. They are similarly priced and quick shipping. I will just watch to see prices as I near a project as they occassionally have either free shipping or slightly marked down sales. These D-ring mounts came from Ruffstuff Specialties and were $20/each. These are very nice components, actually a bit nicer than the ones from AtoZ, very similar to the Ballistic Fabrication ones I purchased years ago for my JKU bumpers as far as finish.
I could definitely machine these components as well as the spindle kits but for the cost it almost negates the time required.
Thanks again for the comments and for following along guys.
Z
zmotorsports
Northern Utah
I was able to get a little more work done on the TJ bumper tonight. Merely filling in panels.
Using my CAD abilities. Cardboard Aided Design.[emoji12]
Transferred to .125” P&O sheet.
Tacked into place. Both sides are identical so mirror images side to side.
A few of the welds prior to knocking them down and blending.
Bumper itself is welded.
Next up is to locate where the spindle will be for the carrier then remove the bumper and blend in preparation for fabbing the carrier.
Thanks for looking.
Z
zmotorsports
Northern Utah
I metal finished the bumper tonight and measured for the spindle placement. Next up is the tire carrier fabrication.
Thanks for looking.
4 FN 27
Minnesnowta
Mike I have worked with some of the best metal finishers around...and you would give them a run for their money. Nice!!!
Z
zmotorsports
Northern Utah
Thank you Pat, I'm flattered.
I've seen some pretty impressive metal finishing work and I don't quite feel like I'm there yet. Maybe one day when I grow up my fabrication skills will come around. :beer:
Thanks for checking in on my projects Pat.
yaidunno
WI
Looks like you've been staying busy Mike! The bumper is coming along nicely.
