Looking for a lift
heffneil
Naples FL
I was looking for a lift and I think I narrowed it down. I was talking with ASEDeals and I might just buy from them but before I pull the trigger I was wondering if anyone did a garagejournal discount that I should price out before moving forward?
Thanks!
Neil
H
heffneil
Naples FL
Well that’s good advice. I feel like customer service has just disappeared in this internet crazy world. It’s all based on price and with that no one cares or provides good customer service.
James-W
Southeastern Wisconsin
What type of lift are you thinking about? 2 post work lift or 4 post storage lift?
Just a question, how come so many people refer to a 4 post lift only as a "storage lift"?
I say this because I have a friend who has a 4 post lift and he does all sorts of vehicle work on it. I have been to his house several times and he has been working on a vehicle and I have at times even helped him work on projects. The 4 post lift works quite well and I don't understand why so many people consider it for storage only. That's why when I hear the term "storage lift" when referring to a 4 post lift makes we wonder why that terminology is used. I know a 4 post lift can certainly be used to store a vehicle, but it is a lift and all sorts of work can be done on a vehicle using it.
dmitrysgarage
Houston
The differentiation is really not so much 4-post vs 2-post, but "chassis" vs. "drive on". It's generally accepted that it's much easier to work on a chassis lift, since you can easily go wheels off and maneuver around the vehicle. Of course chassis lifts tend to be 2-post, and that also helps because there is less stuff in the way of you maneuvering.
Some 2-posts lifts can be adapted for storage to lift the wheels like a drive-on lift. Typically its better to store a car on a drive-on style lift because the suspension isn't in full droop.
You can do work on a drive on lift, especially with a bridge that can jack the car up off of it. Or if you're just doing simple exhaust work, alignments, etc...
EDIT: Also some people prefer 4-post as they feel that it's safer. I have friends that won't go under a 2-post lift because it scares them. Statistically that's probably true, though I doubt that any properly maintained 2-post will kill you if you are loading it correctly. I'd wager majority of the accidents are going to be maxed out weight and poorly balanced. It's like towing with a truck, the little Chevy Colorado might say 7,000lbs, but would you tow 7,000lbs with it? I wouldn't. Hell even a gasser full size truck will be a burden to haul 7,000 lbs in for meaningful distances. You go diesel HD at that point.
H
heffneil
Naples FL
I am looking for a 4 post lift. I actually want to store tractors on it in a perpendicular manner. The front and back tires would sit on the treads!
H
heffneil
Naples FL
Yeah I plan on putting the casters on it so I can move the lift around. I like the bendpak product. It looks cleaner and best put together. Despite not using the full weight capacity of the lift for tractors I want something quality in my garage.
ZipSnafu
Virginia
I too have a BendPak and am very satisfied with it. I was very happy with the quality all the way around.
H
heffneil
Naples FL
Yeah I don't know if I should bother going with a less expensive product and I don't think there is too much of a savings with perhaps a sacrifice in quality...
I did notice Northern Tool was like $20 less than the quote I received but probably not worth my loyalty for the help I received from ASE.
jfitz
Eastern Ontario, Canada
I also have a Bendpak HD9XW with an RJ45 rolling jack. Its 3yrs old now, should have got one 10 yrs ago! Doubles as a working lift and then I use it to store my summer toy in the winter months. Turns my 2 car into a 3 car garage. The 2 vs 4 post lift debate will never end. Get the lift that best fits your needs
brownbagg
prices are pretty much lock in due to everybody buys from the factory. like bendpak, doesnt matter who you buy from, its all the same price and it will come from the factory, the dealers are just brokers
scottmoyer
Central FL
If you want good quality and a sturdy frame, look at Advantage Lifts. For the same price as the BendPak, you get full boxed columns, 12x12x5/8" base plates, 4 drip trays, 4 casters, 2 wheel chocks, a 4500# rolling jack tray and excellent customer service.
ToppDogg
For what its worth Bendpaks are made in China.... Rotary Lifts are made in the USA
H
heffneil
Naples FL
Rotary are 14,000 lbs! And they are quite expensive....
Advantage Lift looks interesting. I might check them out.
Oldbear
Linden, Alberta, Canada
Check with some of your local equipment suppliers. One of my suppliers sells lifts and will sell a used lift from one of their other customers. Be picky though; ask for inspection records. In Alberta (or at least my County job), we must have our lifting equipment inspected on an annual basis, and they should have records of it. They would sell me a commercial quality lift and set it up for the price of a new "budget" lift.
I had a few choices - one was old and very used - but had been inspected/serviced every year (with paperwork), one was being replaced as it was too short for the jobs the shop was taking in and one was a switch to an alignment lift.
I've put my name on a Bradbury wheel-free that came from my current workplace - we switched from a 4-ton to a 7-ton lift (from our local supplier) when we built our new shop. It is safe but not brand new or as shiny. I can repaint it for a lot less than new.
It helps that I'm the purchaser, so I have the contacts. But it's worth your time to make some calls.
rburke65
Canfield, Ohio
Perpendicular to what? And what does that mean....tires sitting on the treads? Isn't that where tires sit normally....on their treads? Thx.
Diesel Dan
TN
Worth lifts are made in Texas.
The freight carriers damaged both of my power units, different states, different carriers. Worth sent me replacement ones and dealt with the carriers directly.
lakeroadster
Central Colorado
lakeroadster
Central Colorado
Perpendicular to what? And what does that mean....tires sitting on the treads? Thx.
He's going to let the lift down, then back the tractors sideways so the front wheels set on one runway, the back tires set on the other.
The front and back tires would sit on the lift runways!
Think lawn tractors...
H
heffneil
Naples FL
Yes that is correct. These are John Deere lawn tractors from the early 80's. I figured the back tires on one tread and the front on the other tread. I believe it will work and if not I will get some 2x12's and use them to drive the tractor up on.
H
heffneil
Naples FL
heffneil.. I'd suggest you only by a lift that has ALI certification. Here is a link to the list of which one's are.... Directory of Certified Lifts
Not all Rotary Lifts are made in the USA. Call them and ask about the specific model you are wanting............. Contact Rotary Customer Service
Looks like the bendpak I was interested in is certified? I read somewhere people said that if it doesn't have the sticker on it, it isn't certified.
lakeroadster
Central Colorado
Automotive Lift Certification..... Look for the Gold Label
  • ALI-Certified-Automotive-Lift-2015Gold-Label-on-lift-cropped-view-1024x278.jpg
