Who here USES the one Key functionality ? Never have yet or took out the time to do mode 1, 2, etc
I use it to start fasteners slow then high rev, for projects. Comes in handy.
Its subjective, like ratchets, one size doesn't fit all. Choice is good.
No wonder, the 3/8 is almost useless even in fuel2763 and 2754 (3/8)
Sent from my SM-N950U using Tapatalk
Return it, the car I meanLol, yeah but I wasnt using the 3/8 on the lug nuts.
The bolts holding the bed down on my truck..needed the big gun.. truck is a 95 and appeared to be the first time the bed was ever removed so it gets to use that as an excuse, combined with needing extensions to reach.
Lol, sounds like a lube monkey has a 3/4 air impact wherever you took itYeah whatever...
I used both the 2655 and 2763 to remove the bumper on my pals old Silverado truck. The compact didn't get much on it own but with the High Torque more often than not had hard time getting a good placement I really need some heavy duty universal joint impact adapters. There a set assorted sizes at TSC store I have been eyeballing figure with 15% coupon off at some point I might get for around $20. It's never on clearance
https://www.tractorsupply.com/tsc/p...pact-universal-joint-adapter-set?cm_vc=-10005
How they might hold up I dunno but it's worth the shot. I have the full adapter set in various sizes for all my different impacts and ratchet same brand and been beating on the 3/4" adapter with high torque no problems.
IMO they are really decent.
https://www.tractorsupply.com/tsc/product/jobsmart-8-piece-impact-socket-adapter-set-125228799--1
Trouble was on the bumper I needed 18mm deep for few spots and they only one I had was 3/8 drive, a reducer snapped instantly under the high torque.![]()
Isn't that the one where you can swap heads and make it a drill or a multi tool? I think it only has like 20ft/lb of torqueI think I'mma just throw it in my work van or car in case of a flat. We'll see... Oh - good, now I can buy a glue gun... Lol
What - Ryobi has an 18v ratchet?
Can't wait to get some feedback on both of these once you get them and give 'em a try.I got my shipping notification for the M18 sander and the M12 inflator. Should be here soon.
They are both tools I've been hoping Milwaukee would make for awhile now.
Some more HD clearance updates, M12 Fuel packout promo thingys $70, Sawzall 9.0 kit $175, Circ Saw 9.0 kit $187
Bought the 9.0 saw all a few weeks back and did a return rebuy for the updated clearance price. Also picked up the gen 1 hammer drill pack out kit for $80. Might as well do the same for the m12 as well.
I've got either a bent rim or a leaking valve stem that I haven't gone out and messed with yet so I've been filling up one of the tires on my truck every couple mornings. I think it'll be perfect.
I've also got the M12 underhood light arriving tomorrow so it will be a very Milwaukee day.
I am way down the pre order list, dont think I am in Acmes batch 1 or even 2 shipping because I resisted even till 10% day 2.
I am seriously skeptical how good it will be for 3 reasons; its M12, its small, and its relatively inexpensive at $69, think most of us thought it might be $80-100. Hope it can add 5-10psi very quickly. If it takes 1 min to add 2-5psi like my jump box I will be very disappointed.
One day sale on cordless nailers 16 ga and 18 ga
https://www.homedepot.com/SpecialBu...150373&cm_mmc=CJ-_-4150373-_-11210757&cj=true
Unless I missed it, there is no flash sale on tool only, correct?
No it's for the kit.
Its all the in the HD link
I have to say I believe it's $20 less than I paid more than a year ago
Hahaha like any of us NEED every tool we own [emoji23]Ya be curious on the runtime...What kind of work do you do you need a cordless palm sander?
What about that underhood light. Were you doing a review on them?
Sent from my XT1635-01 using Tapatalk
Haha my garage door opener is on the same circuit as the lights controlled by a switch 3 rooms away lol if I want to use my remote in the car I have to leave the lights on all day long.Biggest reason I try to get everything cordless is I have a single circuit for my garage, and overhead lighting, and den, and laundry room with washer... This actually means I can use the dust collection adapter with my shop vac without worrying about tripping a circuit.
As for the underhood I'm hoping to start shooting a big comparison review soon. Similar to what I did a while back on the M18 Work Light vs. Halogens and the Snap On LED everyone on GJ was buying back when.
You don't need any tool until you need it, then it's too late!
What's the largest battery it will take and does it hook to the m18 vac
