Backyard Imports
So I am looking for a blade to use in my table saw to cut through some 2” rigid foam that is enclosed in fiberglass. I know that it sounds a bit strange but I got an unlimited supply of door sections that I want to use to insulation one of my outbuildings. (Basically, a door company has solid slabs and then uses a CNC router to remove the center sections to install glass.) I want to be able to just run them through my table saw and cut them down to 14.5” to use between wall studs.
I am unsure if I should just find a blade that has a ton of teeth and is a bi-metal type or maybe get something more along the lines of a cut off/abrasive wheel.
What do you guys think?
