What type of blade?
Backyard Imports
western WA
So I am looking for a blade to use in my table saw to cut through some 2” rigid foam that is enclosed in fiberglass. I know that it sounds a bit strange but I got an unlimited supply of door sections that I want to use to insulation one of my outbuildings. (Basically, a door company has solid slabs and then uses a CNC router to remove the center sections to install glass.) I want to be able to just run them through my table saw and cut them down to 14.5” to use between wall studs.
I am unsure if I should just find a blade that has a ton of teeth and is a bi-metal type or maybe get something more along the lines of a cut off/abrasive wheel.
What do you guys think?
never enuf time
North of the Motorcity
If the table saw is a good one, I might be concerned about the fiberglass wrecking it.
If it's not top notch, go for it with a cheap carbide blade. Can use a cheap 7 1/4" blade flipping it over to complete the cut.
Backyard Imports
western WA
“Flipping it over”? Do you mean running it backwards? I have never done anything like that before. What does it accomplish?
And the saw that I would use is a $300 portable setup from Home Depot. Nothing special.
Wamsutta
Amarillo, Texas
I would just use the same blade I use for everything else. Those Diablo blades leave such a smooth cut that you'd think something was cut with a 60 tooth blade when in fact it was cut with a 24 tooth framing blade.
unslow1
Illinois
I used a regular blade when I sided a couple of houses. The vinyl would start chipping a little when the blade was getting dull.
unslow1
Illinois
We flipped the blade when doing flooring. That worked well. I don't think I would try it with fiberglass.
tab2
Boston
Use your normal blade. When you’re done, pitch it for the next time you cut wood.
exmaxima1
Midwest
A blade with negative rake teeth would work well. Anything that cuts non-ferrous metals and plastics is typically negative rake. Only issue is that the material might want to lift, so run the blade high and/or make some sort of hold down jig.
Voi
Western South Dakota
I should have said flip the panel. If using a cheap 7 1/4" blade it might not cut all the way thru, so would need to flip material over to take another bite at it.
This might not be a bad thing for the OP as the two non-through cuts might keep some of the fiberglass dust contained. Of course it requires that the edge against the saw is straight and flat.
seber
Deep East Tx.
Use any cheap carbide blade but make sure you have a vacuum setup and full face mask including sealed eye protection. I would try to do it outside in a strong wind. Fiberglass is super nasty.
rustyjames
central nj
Total agreement about doing this outside in a strong wind and full Tyvek suit. Fiberglass really ***** when you get a good dose of it on your skin.
