kaymccampbell
Made a handwheel for the shopsmith and fitted up the shop bathroom fan to take medium base bulbs.
Started putting some color up. The few sheets I put up kicked my ***!
needless to say one too many beers
+100pull that set screw out and grind down till it fits. That is a easy way to get your fingers cut or scratch something you didn't want scratched. Just saying, play it safe.
Drilled out the set screw on my 3/8 hex socket, hex bit bit kept falling out. Found another set screw and fixed it, might stick out a bit- but I don't care.
Installed a pressure relief valve and a gauge for tank pressure on my find on craigslist for $19.00 !! Compressor runs great ! I couldn't pass it up !
Pressure switch and gauges were missing, or broken off when I got it.
Went outside the barn and sat in the sun out of the wind and had a beer.
Built some drawers for under my workbench. Drawers run in a 1/4" dado. No drawer slide hardware. Cheap and sturdy - perfect for the garage. Before/after pics.
You have it mounted upside down.
I ”fixed” the rubber glove box holder that I picked up from harbor freight. Fits much better now
PassnThru & BadEyeBill - thanks for the compliments.
BadEyeBill - I dont need a vise often and would rather have the workbench top free of the obstruction. So my vise is mounted on some scrap 3/4" ply and when I need it I put it up on the bench top and clamp it down with some squuze clamps. Works like a charm.
Now that you did that, they are going to change the size of their boxes!![]()
A bit more... the drawers are modular. The dados were cut every 2 inches. It gives me drawers of 2", 4", and 6". Best part is that they are all interchangeable.
Will you be waxing the guides to help lubricate them? Wood on wood tends to bind and jam when it swells with temp changes.
I ”fixed” the rubber glove box holder that I picked up from harbor freight. Fits much better now...
So while listening to my tunes I started working on putting back my remote controlled retractable licence plate frame on my Mustang now that I got my pony back from the paint shop...reinstall the unit and it works great!
Why do you need that?
Because it is cool, and for car shows.
I was looking at that holder but thought it was a bit expensive...what was wrong with the original design that you had to "fix it?"
Just happy I didn't buy one after reading your post.
I walked into the garage and noticed the display on my bookshelf JVC stereo system was not displaying...anything.
Tried to turn it on, no work...checked the plug, getting voltage...hmmm.
Well, unplugged all the speakers, antenna, and aux jacks, and brought it over to the bench.
First time this unit ever failed to power up so I popped the cover...
Checking the power board the cord goes to I see fuses! You would think they would have a external fuse holder, but no...
Sure looked like a blown fuse. Pulled it and sure enough, Blown!
How did that happen?
It wasn't running when the fuse blew!
And good luck finding a mini glass fuse.
So I go to my fuse drawer, none, check my misc drawer, nope...checked here, there...I only have the longer regular glass fuses.
Check the fuse drawer again and hey...what are these? MINI FUSES!!!!!
How did I miss them?!?!
Whoopie! And the right amps too!
Wow, my lucky day!
Put the fuse in, tested the unit and it works!
Put it all back together and no problems since however....
I did have a bad speaker in one corner of the room and I was trying to make the time to get to it...could have been the cause, I suppose.
So I fixed the speaker cabinet by replacing the speaker with one from my truck.
Sounds better than it ever did now...
While working on my licence plate holder I noticed some cooling fluid dots on some of my the engine bay components and the engine timing sensor....looks like my pump is starting to weep...may have to replace my cooling pump...better see how much for a new once and replace it before it dies.
So not for the tollways.......riigghhtttt
That's pretty cool. Are you any relation to James Bond?
