Question for the Electricians
Wamsutta
Amarillo, Texas
Say I have two identical SKIL worm drive circular saws. Both have 13 Amp motors. One hooked up to a 12/3 50 ft extension cord and the other hooked up to a 10/3 50 ft extension cord. I hook an inductive ammeter around the 12/3 extension cord and make a cut. I then hook an inductive ammeter around the 10/3 extension cord and make a cut. Will the ammeter readings be the same, or different?
Sycan
Same, now use a 16 gauge cord and maybe you'll see something. 12 gauge is more than adequate for 13 amps.
Sent from my E6810 using Tapatalk
W
Wamsutta
Amarillo, Texas
Thank you I appreciate your answer. I'm trying to get the saw to run as cool as possible. It's one of the last USA made saws.
grounded-b
Milwaukee, WI
If you put the ammeter around the entire cord you will always read zero amps.
The current on the neutral cancels out the magnetic field created by the hot
You need to clamp just one of the conductors
Steve
DSLTRK
PHELAN, CA
Voltage drop over 50 foot for just 13 amps is negligible. 12 gauge is fine, even a cheap 14 gauge cord is fine.
zktk01
KY
Steve
What he said
