Post-rack pole barn shelving brackets
ishiboo
Oshkosh, WI
I keep seeing these on Craigslist (spam, unfortunately) and I thought I would share as they do seem well-designed. They're heavy-duty shelving brackets for pole barns.
They run $75 a piece but they do look to be a nice solution.
No affiliation, though they do say they are made in Wisconsin! http://www.post-rack.com
joe_padavano
Northern VA
So, $450 for the six brackets in that photo (plus the lumber for the actual shelving). I paid considerably less than that for used pallet racking with more shelf space for my pole barn.
I
ishiboo
Oshkosh, WI
Yes, there are cheaper methods... but this gets it off the ground and doesn't require you to build your own, and has no angled support under.
joe_padavano
Northern VA
Watch that you don't pull the barn down. Pallet racking stands on the floor.
^^^THIS. The brackets in the photo impose an eccentric load on the poles, especially if you are using them to hold heavy items. Combine that with a heavy snow load and the poles can buckle. "Eyeball" engineering is not a replacement for real load calcs.
chaosracing
Kutztown, Pa
joe_padavano said:
I have seen these before, but like said above, way to expensive and the loading on the poles is not good.
Pallet racking is easily found. There is a salvage yard near me that has about 8 to 10 tractor trailer loads sitting in their yard right now, maybe more than that.
