Trailer Refurb
Bretny
Dutchess county NY
Nice build.
Your going to be asking alot from a single battery. I have s winch on my car trailer thats hooked up to my vehicle battery. If the trucks running it never goes dead and not another battery to take care of/replace.
I drag logs onto my trailer so a little more dead weight and i could have nearly 100ft of line out. I fit about 4 logs on the trailer.
I
Iroc-Z
New Germany, MN
I was originally planning on two batteries but space is limiting me to one. A guy I work with has a similar trailer and set up with one battery. He says he has never had a problem with his deep cycle battery pulling up a car and running the ramp. I am putting on a trickle charger on top of having the truck charge the battery. Trailer will be plugged in when parked at all times. The use of the trailer would be to go and pick up one car a day max. I only probably use the trailer about 3-4 times a month.
NUTTSGT
Northern Central Ohio
Big delay and not allot done. My wife went into labor on Wed and gave birth to our third child. So a little busy not sleeping.
Working on the battery tray but everything will be self contained in the tool box.
Congrats on the new child.
Have you considered adding a removable shelf above the hydraulic pump for added storage space in the box ?
jam022316
Indiana
Nice. I refurbed my car trailer about 5 years ago. I ran all the wiring in Liquid Tight conduit and kept all the grounds inside junction boxes. Used all stainless hardware and it seems to be doing well. Something to consider...it didn't cost much.
That is brilliant!
I
Iroc-Z
New Germany, MN
Yes I have. I am going to figure that out after final assembly. But was thinking I can utilize the space. The only thing I need access to is the winch cable release leaver.
I
Iroc-Z
New Germany, MN
Good by to pump jack.
Hello hydraulic ram.
Ready for blasting and paint
Guy I dropped it with said he should have it blasted and painted by Friday. Then I can get to assembly.
Earp69
This things things be slick man keep up the good work
Sent from my SM-N910V using Tapatalk
jeepinerdeep
South Central PA
Don't forget to do something to preserve your VIN tag. Only one I found on mine was the sticker in the tongue.
Mine started to peel so I laminated it fast. I want to add a second hidden one somewhere in case of theft sometime.
NUTTSGT
I think mine is stamped into the trailer tongue on my open trailer.
Earp69
What'd it cost you to get it blasted and painted if you don't mind me asking
I
Iroc-Z
New Germany, MN
What is he going to paint it with ?
Brand/type of paint ?
Not sure. He is priming it with an Epoxy primer and multiple coats of low sheen black. Guy does allot of blasting and painting of equipment. (Dump trailers, bobcats, etc.)
I
Iroc-Z
New Germany, MN
More then I wanted to spend. Total for everything is going to be around $1500.00. One place quoted me $2800. I laughed and told them for another $1200 I could just buy a new trailer.
I
Iroc-Z
New Germany, MN
I was worried about that but I just took a picture and will have it remade. There are places online that will do it.
bradpac
Central TX
Trophy shops can make some good looking vin tags. We recently put them on our the specialty made trailers at the company I work for when the police started getting pickier about things down here.
Earp69
You could also Weld the letters and numbers into the frame somewhere hard to find. Little late now I guess
I
Iroc-Z
New Germany, MN
Back from blasting and paint.
Came out really good for what I am looking for. Didn't realize I warped out the fenders as much as I did but they will be fine. Going to start with wiring the lights next then getting the deck put back on.
mrolds88
WV
Like your work on this J. But one question, what is the fitting that is coming out the middle with the brown and white wires? I also like the stainless hardware too!!
