What does Lowes/HomeDepot use
Bradbilt
Gilbert PA
What dod the big box stores use on their concrete floors in the stores?
Is ia sealer? Would it hold up in a hobby car garage?(torch splatter)
Lelandwelds
Central Texas
They use an industrial concrete contractor with really cool ride on concrete grinders. Everything is specified and planned from the start.
All else is minor.
LegacyIndustrial
deerfield, IL
Once the initial power-trowel slick-trowel is done...
They maintain using a Diamabrush Polishing head on floor machines.
They use products like our HD40 Concrete StainGuard to keep it looking snappy!!
They do get a full fledged touch-up every now and again by outside contractors.
Armorpoxy
The don't use a product, what they are doing is polishing the concrete with grinders as noted above. They go over the floor with finer and finer diamond pads and densify and add a sealer that gets burnished. This process is normally too expensive for residential applications, plus it doesn't have great resistance to oils, fluids, etc.
Our Installation Division, Prep Crete does hundreds of thousands of square feet of polishing annually...see https://prep-crete.com/gem-polished-concrete/
If you like that 'look', use our clear SPGX polyurea hybrid one part coating. It gives a nice sheen while being very easy to apply.
MDM
Florida
What is the cost per square foot of the spgx?
Can it be applied directly to a power troweled floor without grinding?
Thanks.
LegacyIndustrial
deerfield, IL
Lowes, Home Depot , big box stores polish OLD floors, the early stores. The new stores look they way they do because of how the concrete is finished and treated immediately after finishing.
They would go broke polishing all the new stores!
THD started 98-99 with polishing in existing stores. As time progressed the finishing techniques improved tremendously. This all started in the Northeast region and yours truly was the salesman who got them onboard!!
Bradbilt
Gilbert PA
Sorry for the late response, it seems my email notifications is NOT working.
So is there any type of product that would work in my home garage that I could afford AND that would "seal" the floor from the oil/grease yet still hold up to torch/weld splatter?
Armorpoxy
Ghostshield densifer/sealer system will seal your floor from oils and liquids, and since it is a penetrating sealer it won't change the finish or look of the concrete at all, so it will handle welding slag and such.
Any topical coating like an epoxy, polyurea, etc is subject to burn marks from welding slag. Sparks should be find on a coating, slag can cause minor damage so if you go that route use welding blankets or sheet metal to protect the floor.
Bradbilt
Gilbert PA
Thanks for the info!!
