Best cutoff wheel for a dremel?
flynnr
I searched and couldn’t come up with anything. Sick of the ‘reinforced’ cutoff wheels shattering on me and going dull in 5 mins. There are some metal ones but they seem to be pretty spendy for what you get.
Is there a good alternative? Doesn’t have to be dremel brand, but must work with a typical dremel. I don’t mind spending the money on a good set of it will last.
Thanks!
GTO
NJ,FL
If the Dremel discs are shattering,the metal you're cutting is to heavy in gauge.
vjquan
I just use generic fiber reinforced wheels that are 1.25" in diameter.
F
flynnr
Yeah I have a rotozip as well but the space I typically use it in for my job isn’t very big and it’s easiest to use the dremel.
I guess I probably overexaggerated with how often they shatter - it’s not all the time by any means but does happen from time to time.
Aside from other tool recommendations, anyone have any insight for the dremel?
nes999
IL
What brand Dremel wheels do you use? I've noticed a wide range in quality from various suppliers.
Sent from my VS988 using Tapatalk
Parrothead
Earth
I used the fiberglass reinforced wheels made by Dremel. I'd agree, if you're blowing through them you might need a different tool. I use a lot of them, and wouldn't consider it an issue.
PhysicsDude
Dallas, TX
I use the Dremel 1 1/2" wheels with EZ lock from the link above. Its the best way to use cut-off wheels with a Dremel IMO.
That being said, I don't really care for dremels for cutting, I use something bigger whenever possible.
mbshop
visalia ca
I have never had one shatter. course I don't use it for heavy duty work either. I use the reinforced ones as shown above and the get the job done. also you may be forcing the cutting to much, just let the disc do the cutting without forcing it. or look into a foredom setup.
ssdave
Eastern Oregon
The thin damascus cutoff wheels are a cheap, expedient, disposable item. I buy the unreinforced ones by the 100's, and go through them by the 100's. So they break. What does it matter? Put another one on and go at it again. Using these cutoff wheels is the very best reason to own a dremel tool. It's the thing that the dremel does that no other tool does as well.
You can get the thicker reinforced ones and they don't break, but they are thicker, cut slower because of that, and cost more.
Buy some of the thicker, reinforced, higher cost ones. Use them when appropriate, or use the cheap thin ones when they will work better. One thing I do with them is stack them on a mandrel to make varying thickness grinding wheels.
I use a dremel mandrel and the thin damascus wheels often in my mill or in my drill press with a x-y vise to cut hardened steel, or to slot it. They essentially never break when held steady in the mill, and can hold an incredible tolerance for straight cutting. Great for making custom screws, for slotting the heads. Or, for cleaning up buggered up screw heads so they can be removed.
I use these cutoff wheels for an incredible array of things. Cutting off allen wrenches to make refills for my hex bit sockets. Slotting hardened steel parts. Cutting off 18 ga finish gun nails that don't get fully driven. Recutting screw heads. Custom width grinding wheels. Slitting sheet metal items. Cutting ceramic or glass items.
Leaflessshadetree
Don't ask.
It really depends on what you are cutting.
I mostly use the emery cut-off wheels (the thin ones), and often double them up.
Very useful for cutting a small slot, like for a screwdriver tip. or cleaning up grooves.
I don't usually use it for cutting things more that 1/8" diameter.
It also isn't uncommon to shatter one, so wear eye protection. The pieces are small and light.
pilotmotor
when the 3m greencorps wheels I use on my 3" cut off wear down too small I use them on the dremmel . Just have to make a mandrel
Maui
Upstate NY
I found that you can effectively eliminate this problem with the blades shattering by taking two of the thin cut-off wheels that originally came with the Dremel and stacking them together like Leafless mentioned. It works surprisingly well.
Wamsutta
Amarillo, Texas
GYROS
unknownroad
WNC
The thin damascus cutoff wheels are a cheap, expedient, disposable item. I buy the unreinforced ones by the 100's, and go through them by the 100's. So they break. What does it matter? Put another one on and go at it again."
It's all fun and games until you fumble the itty-bitty set screw and have to crawl around on the floor hunting for it. :sad:
The cost of the reinforced EZ-lock wheels makes me cringe, but the time spent replacing the damascus wheels adds up after a while.
F
flynnr
Thanks guys I am going to order the gyros and the ez lock set and give Er hell
On-Wheel
160 Pc kits are best bang for buck if shopping for ez-lock ( only 3 disks )$24 vs $15 for just ez-lock and 5 disks.Man those are priced like a BMW bearing,only available at dealer ship for $100 when its a $3 bearing.lol
If discs aren't exactly centered they hop and shatter,I've had a few that way.Just a little might as well be egg shaped.lol
