I need help understanding how to connect my air compressor pressure switch to my magnetic starter for my franken-pressor.
It has a 5 HP IR motor (22.8 amps) with a 440A LeRoi-Dressor pump and an 80 gallon IR tank. When I bought it, it only had a pressure switch powering the motor. It worked, but from reading GJ, I knew that using only a pressure switch for a 5 hp motor was bad. Hence, I bought a new 25 amp pressure switch from Surplus Center and a 7.5 hp magnetic starter from Weg/Temco (the L-D pump can be used with a 5 or 7.5 hp motor; I wanted to be able to upgrade later if this motor went out).
Here is the pressure switch: https://www.surpluscenter.com/Water...our-Port-25-Amp-Pressure-Switch-4-1823-H4.axd
Here is the motor starter: https://temcoindustrial.com/weg-esws-50v24e-rm38-motor-starter.html
Pic of the inside of the pressure switch; ignore the current wiring, I'm going to redo it. The center two terminals are marked "Line"; the top two are marked "Motor" (the bottom two are for the grounds).
Pics of the motor controller (again, ignore the white wiring just below the top white box):
On top of the above pic is the coil, which is not visible. Here's a pic of the coil; note that this motor controller has a 240 VAC coil - which is where my question is going to come from. The lugs for L1 and L2 are just barely visible at the bottom of the pic. The coil terminals are marked "A1" (left) and "A2" (right):
And here is the wiring diagram for this motor controller from inside the MC cover (it also repeated on the 2 page .pdf data sheet on the Weg/Temco MC site). Note the terminals marked "A1" and "A2" just above the center of the diagram.
So my question is as follows:
Since I have a 220 VAC motor controller coil, I then need 220 VAC delivered to the MC coil from the pressure switch - Yes?
And since a 220 VAC circuit consists of 2 wires (hot-hot; ignoring the ground):
I then need to have 220 VAC (hot-hot) to the two terminals marked "Line" on the pressure switch, then 2 wires (hot-hot) from the terminals marked "Motor" from the pressure switch going to the two terminals (hot-hot) to the MC coil terminal marked "A1" and A2" - Yes?
Or am I missing something and over complicating this?
Please help me get from the pressure switch to the motor controller without burning up the motor, the pump, my shop, my house and the surrounding 38 acres of my woods.
Thanks!
Thanks!
