vtsoundman
I am working on a house renovation in California. A panel needs to relocated (about 20 circuits) - I've gutted the old panel and will be using it as a junction box.
My questions is this: can I use DIN Rail terminal blocks or barrier strips instead of a CF of wire nuts? Code says the blocks must be listed -> some buddies (outside of CA) have said it is fine and accepted practice. What say the Cali based sparkies?
I'm familiar with and have designed equipment using DIN rails...so specing a 1492 connector is no big deal.
Other details:
The new box is within 24" of the old (but the romex cannot be moved as it isn't long enough) so I using the 24" ****** rule and stuffing #12 THHN into 2 x 1" FMC conduits. Single #12 EGC (no circuit larger than 20a) per FMC.
Other details:
