Snap-On KR421 Restore
thehorse13
Jefferson County, WV
Some of you might recognize this 1958 KR421 middle box from the toolbox thread. For those who haven't seen it, I picked this up for 12 bucks at a sale.
It's time to get this gem back into service.
Someone spray bombed it with blue paint and tried to break into the box using a pry bar. After some acetone wiping and some metal hammering, we are back to being level again.
I cleaned the Snap-On badge and placed it to the side for the finishing touch after the long road of stripping, straightening and painting takes place.
Here's where we begin.
Alienbaby17
Minnesota
Nice score!
So much eye candy in that first photo, Alemite bench, F100 grille, vintage Snap-On...all good stuff!
T
thehorse13
After removing what felt like 10 pounds of filthy grease from the slides, this is what I'm left with. The tan residue looks and feels like wood putty that hardened 50 years ago. A date with the wire wheel has been set to get them cleaned properly.
As for the box, after wiping away the blue spray paint and layers of grime, I'm left with exactly what I expected. A worn out old Snap-On finish. No worries though. Soon everything will be shiny red and new again.
Shelbylex
I love the restoration threads. The horse13, please give us all the details about sanding, prepping and painting!
T
thehorse13
Shelbylex
thankyou, thehorse13. I use these threads to learn as nobody around me is into tools and tool boxes.
Great work on Alemite! Were you ever able to complete the set? If not, I will keep my eyes opened and hopefully will stumble upon one of them for you.
T
thehorse13
I had minimal time to fool around in the shop today but I did manage to get the slides cleaned up. I also managed to get one of the drawers started on the paint stripping process. If I burn through Mrs. Horsey's list of things to do this weekend, I hope to get all 3 drawers down to bare metal.
T
thehorse13
Getting the paint off of a late 1950s Snap-On box is no small task. The paint quality back in the day was far better and it takes quite a bit of elbow grease for removal.
I've found that Jasco stripper works pretty well at a reasonable price. I'm sure there are more expensive and/or better strippers out there but this is what I use.
You can see the results of leaving Jasco on this drawer for about 5 minutes. Once I get all of the paint off with this gel stripper, I will move to the wire wheel and hand sanding.
T
thehorse13
As I noted earlier, 1950s paint is a lot tougher than modern stuff. I rolled out my buffet of grinding and sanding wheels to get down to business. I did not use the HF sand blaster or the electric grinder seen on my mobil restoration cart. My little Monarch bench vise was just along for the ride this time.
After bringing drawer #1 down to bare metal and fixing a few minor metal bends over the weekend, I was able to prime, sand and shoot the drawer today. I'm letting the drawer bake in the sun this afternoon before bringing it back into the shop for the night. It will require a second coat tomorrow.
T
thehorse13
The large bottom drawer had a lot of pitted metal under the rust. When I run into this issue, I always hand sand the surface so that I can apply pressure to the problem areas. Notice that I have a free slice of sandpaper and no block. This is on purpose so that I can feel what's happening to the metal as I go along.
Here is a teaser pic of the same drawer. Things are coming along nicely but I have to address a few areas, especially the seems. You can see that paint needs to be evenly removed from the back drawer seem if you look closely. This drawer also needs a second coat of paint.
up a creek
Thunder Valley
Looking good! I see you have a few other boxes to the side of some of the pictures. Did you also refinish those? I have an older snap on carry box it is Army Green with some rusting. I would like to paint it White with a Pearl finish over the top. Keep up the great work. BTW, that price you paid is Outstanding!
T
thehorse13
Some were redone while others were just given a really good cleaning. It is a fine line between well worn patina and a ragged out old tool box. :)
up a creek
Thunder Valley
I like all the box styles you have pictures of. I will be looking forward to the final product when you are done. Thanks
T
thehorse13
Horse, are you spray bombing these with Rustoleum Sunrise Red?
Unfortunately, I do not have the ability to setup a paint booth in my garage right now so I'm forced to use spray paint. That said, if you practice long enough, you can lay down a finish extremely close to what someone can do with an air gun. The most critical part of painting is the surface prep work. 95% of the time, this step is done wrong and the spray bomb finish highlights the errors.
I'm using the 2X Rustoleum paint in cherry red. It will look great when I'm done and I will even shoot the box with clear coat when I'm satisfied with the finish.
Lookin4'67Galaxieconv
Atlanta, GA
Agreed on all counts. :thumbup:
What kind of clear coat do you use?
T
thehorse13
When you're trying to sand decades worth of filth off of an old toolbox, you're going to find that your sandpaper is going to clog up with material. I've watched people throw away perfectly good supplies because they didn't do one simple thing; turn on the shop-vac.
If your sandpaper looks like the piece in the picture, just hit it with your shop-vac for 3 seconds and you're ready to get back to sanding.
Now that we've gotten in one small shop tip, you can see that things are moving right along. If all goes well, I will be clearing everything by the weekend and assembling the box by early next week.
So far I have two drawers and the box sprayed with a base coat. Once I get the final drawer done, I will move on to second coats, clear coats and wet sanding.
up a creek
Thunder Valley
Amazing job you have done so far! That was a great tip as well. Works when sanding wood as well. On your wet sanding, do you spray clear then sand, and then buff it out, or do you wet sand before the clear?
T
thehorse13
If I'm looking for a showroom shine, I sand the base coat, thoroughly clean the surface, clear, then sand again. You'll be blinded by the shine when the sun hits it. 2000 grit is what I use on the final sanding.
T
thehorse13
Today is test fit day. I check slides to see if they need tweaking, drawer fit, etc. Considering where I started, I'd say this little box looks much happier.
While I'm thinking about it, I like to use blaster dry lube on tool box drawer slides. I use this particular lubricant because of the amount of dust that's in the air around here. If I used any wet lube, I would be changing it every year or so.
Because this is a spring drawer, the top drawer will stick out about half inch when the box is unlocked. I don't have a key so I will either get one made or simply disconnect the two springs in the back of the box. Either way, we're certainly making progress.
T
thehorse13
lol. Yea, it will look brand new off the Snap-On truck in 1958 after clear coat and wet sanding.
That said, Mrs. Horsey had to go and rain on my parade. She said it will look brand new sandwiched between two boxes that look used...dammit. I hate to admit when she is right (which is always) but maybe I should leave it as is so that it looks more like the other two boxes. I guess I could drop it in place just to see how it looks.
up a creek
Thunder Valley
Very nice work! Turned out great thus far. Maybe you finish the other ones to look as new or leave it like it is, either way it looks amazing!
T
thehorse13
Well folks, we're at the end of the road. After test fitting the middle box, it looks perfect the way it is. My bottom box spent the first half of its life on a boat dock in southern Florida so the paint has faded a bit. Even so, I'm completely satisfied with my 1957/58 Snap-On stack.
One last item was added to the middle box. Wally World drawer liners. I like these because they are less than five bucks and look identical to the Duck brand toolbox drawer liners.
So let's add up the invoices here. $12 dollars on the box, $12 dollars on 3 cans of paint, $4 on drawer liners and probably a few bucks in shop materials. Let's call it 30 bucks total spend. I don't think I can complain.
On to the next project... :)
up a creek
Thunder Valley
Very nice job on the box, and definitely can’t beat the price.
Shelbylex
thehorse13, what an amazing job!!!
I really like your Snap On 352 bottom box. I wonder if this is going to be your next project to match the color of the upper boxes...
T
thehorse13
Nah. I am going to leave the 352 alone. As far as I'm concerned, the late 50s Snap-On stack is complete. All I have to do now is beat Twertsy to the flea markets so that I can fill it with awesome finds. :)
Atlanta, GA
Very nice, Horse. I have that same Snap On roller box I picked up last year. Mine isn't in nearly as good a shape. Planning a restore on it sometime this year.
