Laying out a sub for the back of my shop (easier to pull 1 run) and deciding where to place it. I know I need 30" clearance 36" deep, bUT how does this apply to doors? I assume the cannot be in the space?
Options as you walk in the room:
A) the wall on the left, which would be behind the open door (assuming I install a hinged door)
B) the wall (that the door is on), 20" or so to the right of the door. This gets blocked if I do a sliding door.
I have been leaning towards a normal door, so I don't loose the wall space with a barn door. But if the panel needs to go on this wall I loose almost the same amount of space.
Just checking I understand correctly before making my choice.
