BlueHeart
I'm looking forward to that too. My basement is filling up. LoL!
...Yeah, I should have jumped on that deal but I'm short on funds at the moment!
How's this Saturday for you?
As for the long motor shaft extension, that could be considerably shortened if not eliminated by moving the motor North. Lots of space on the motor mount plate.
I just purchased this pretty little Craftsman 100 (model 103.24311) for my sister who is a handcraft jewelry maker. It has already been restored with new bearing and paint job, so I don't anticipate having to do a thing but transport it to her.
I'm looking for the operating instructions manual for it. Anyone have one or have an online link to one? Vintage Machines doesn't have it. And Google search is not coming up with anything.
What would be crazy money for that contraption?
i'll go look at that one on saturday or sunday, see what is up with it. Here was my second choice, it was a bit more pricey though. What do you think? I really wanted a gold one, as it goes well with all the red in my garage.
sorry for the delay. the one first one with the vari-slo was 150$. the second one the guy wants 175$. at the end of the day, i dont mind fixing up either, i just need a drill press. thoughts?
Looks complete and not beat to hell. Should clean up nice. Not sure what is going on with the center pulley...Found this listed locally, seller asking $250. IMO a little pricy.
Why is that motor angled?
I would get the second one with the factory 3 pulley set up and not bother with the cobbled together varislow assembly that is not factory. Try to get the floor model for $125 and you should be ok!
That is a bit high but the cheap ones are few and far between. If that is an original pulley then i would make an offer.
Hey guys. Who knew it would be this difficult? After this post I will try to update my location. Are my prices high or low? Found this one this morning. its 250$ guy says its been sitting for 5 years. What do you think?
That is a beautiful machine! If I needed one, I'd have bought that one already.
Can you double-check that number? I don't recognize that as a drill press model.
Frank, I picked up the Model 100 drill press today and the model number is off by a digit. The correct model number is 103.24811. The motor's model number is 115.19780, serial number S-7722.
It has the same conical lock handles as my Model 150 and similar 3-handle feed handle but with the small diameter threads, so I assume this is a later DP in the Model 100 series. Any idea as to the time period other than late-1950s to early-1960s?
Very nice condition after being completely stripped down, de-rusted and painted by the person from whom I purchased it; my sister is now it's third owner.
It was intentionally painted bronze; the person I bought it from was very clear that he'd chosen to use the power bronze paint to match those era machines which led me to believe he changed color from whatever the original paint was (presumably gray).
Thanks for referencing the time period for the threaded 3/8-16 hub. I thought that might be another indicator. My sister will be able to have fun with friends sharing that the drill press is older than she is!![]()
ok, so here is the story. i ended up buying this one, because it really is in pretty good shape, and that these people could communicate via email. here are the pics. good side, it really is pretty clean, i don't think that the motor is original, nor this on off switch. bad side, it does have some play, i am trying to figure out if it is the quill or the chuck. the motor is quiet, because it seems new. the light has to go, unless someone says its a craftsman piece. can someone please direct me to the proper thread for disassembly? can the spindle be taken apart and inspected/cleaned? are there bearings or bushings around it? the numbers are 103.24511, would that be 62-64? looking forward to hearing what everyone has to say. also ended up picking up a wilton 645 vise and a 1/3 hp old craftsman grinder.
here is the vise and grinder.
thanks guys for the write ups. love getting up and reading your thoughts. so you think the motor is original? was 250$ too much? i bought it from 2 sisters who are really cool. they watched me try to figure out how to turn it on, funny. wow, it looks and sounds brand new. so everyone is cool with me ditching the on/off switch and lamp? is no swivel table a bad thing?trying to find a picture of what a correct on/off switch looks like. so much to do, but it looks like fun.
So my Dunlap arrived today
Is the pulley supposed to do this?
Not too familiar with the bushing bearing presses but looks like the quill is coming up and touching the spindle.
Bushing could be worn and allowing too much axial movement.
Take the model number and look up the manual on [that vintage machines website]. Make sure all the snap rings are in place that the exploded view shows.
Yeah, that does not sound good.
When you lower the quill, grab the chuck and try to move it side-to-side, do you feel any movement or looseness?
I would be dismantling and checking the sleeve bearings. The pulley should not be lifting like that. Perhaps it is not seated onto the spline sleeve or the previous owner replaced with an incorrect parts.
Check the post in the link below and compare with your machine during disassembly.
https://www.garagejournal.com/forum/showthread.php?p=5658352&post5658352
Installation of sleeve bearings are a little more involved. Usually they need to be reamed to the final size after being pressed in.
