1/2 Cup
Member Emeritus
Bret, I trust your new seal will work better.
You hope.......Not trying to be negative but we all now how these things go.
(In a very poor Jedi tone) I wish you luck, young Brett.
Bret that shifter/boot is looking very like artYour saga on the door sounds like about zero fun..hopefully the new one works better.
Great progress and as always excellent attention to detail!
Hopefully the new one works out Bret! Look forward to seeing it mounted and in action. That truck is awesome!!!
BJ: we all sympathize with your door issue and i'm sure you've thought it out and decided a new door is the best option. did you ever look for a part donor truck or maybe that's not even an option?
good luck!!
20180412_094448 by bjohnson388, on Flickr
20180412_100858 by bjohnson388, on Flickr
20180412_101740 by bjohnson388, on Flickr
20180412_101845 by bjohnson388, on Flickr
20180412_101746 by bjohnson388, on Flickr
20180412_133429 by bjohnson388, on Flickr
20180412_133508 by bjohnson388, on Flickr
20180415_115923 by bjohnson388, on Flickr
20180415_153432 by bjohnson388, on Flickr
20180419_133004 by bjohnson388, on Flickr
20180415_154044 by bjohnson388, on Flickr
20180415_160520 by bjohnson388, on FlickrBeen too long since I have updated my thread. I have been busy and lazy about posting. I blame Motor Trend on Demand!
So I went to get a 1/2" drive ratchet from its drawer and wouldn't you know I have a 36 mm socket. I have no idea why. So I returned the one from Lowes.
While I was at Lowe's I picked up some 1/2" grade 8 hardware for the rear suspension on the 64'. There is just something magical about Grade 8.
Bret
Bret,
I see you jumped onto the MTOD train as well, it has killed a bit of my time in the past few weeks but honestly it was worth the $50 a year to me.
Do LS engines use the 36mm for the crank like the Duramax engines? Also GM trucks/SUV's have a 36mm axle nut on the front. Glad you found the old one before using the new one.
If you have a tractor supply near you I highly recommend going by their bolt area, I can get Grade 8 hardware for $4.49/lb I believe. If I ever need something I don't have on hand I'll buy a few pounds of misc. to add to the stash.
JB
I'm confused. Why didn't you want two 36mm sockets?
Seems a throwback to go back to cartridge filters. That does not make much sense either. So now you have to pour used motor oil down the side of the engine so you'll remember you changed the oil? It seems a lot simpler to just take a spin on filter off and let it drain all over the engine as you try to get it out.
Keep up the good work!
20180417_195711 by bjohnson388, on Flickr
20180417_193018 by bjohnson388, on Flickr
20180417_193002 by bjohnson388, on Flickr
20180417_195350 by bjohnson388, on Flickr
20180417_192939 by bjohnson388, on Flickr
20180419_105827 by bjohnson388, on Flickr
20180419_110310 by bjohnson388, on Flickr
20180419_105630 by bjohnson388, on Flickr
20180419_105635 by bjohnson388, on Flickr
Screenshot_20180419-123349 by bjohnson388, on Flickr
20180419_133010 by bjohnson388, on Flickr
20180419_133045 by bjohnson388, on Flickr
20180419_160228 by bjohnson388, on Flickr
20180419_160627 by bjohnson388, on Flickr
20180419_163202 by bjohnson388, on Flickr
20180422_093849 by bjohnson388, on Flickr
20180422_125137 by bjohnson388, on Flickr
20180422_125614 by bjohnson388, on Flickr
20180427_074126 by bjohnson388, on Flickr
20180427_074327 by bjohnson388, on FlickrI really like your blast cabinet, have not seen that before.
Good to see progress on the '64. You can break it in by running up to see me in it.
20180422_101823 by bjohnson388, on Flickr
20180422_125647 by bjohnson388, on Flickr
20180422_152328 by bjohnson388, on Flickr
20180422_152336 by bjohnson388, on Flickr
20180422_155959 by bjohnson388, on Flickr
20180422_160006 by bjohnson388, on Flickr
20180422_162258 by bjohnson388, on Flickr
20180422_165457 by bjohnson388, on Flickr
20180422_165500 by bjohnson388, on Flickr
Bret, I think LMC Trucks has a fender with slightly less rust and fewer dents. At $339.95 that might be a real nice Mother's Day present. Think how big a smile SWMBO would have if the truck could be finished a month or even a few weeks sooner.
Great updates Bret
A 36mm socket also will work on an old VW flywheel nut (along with 273 ft/lbs of torque - from memory don't quote me on that bit).
Sorry to see the truck is still throwing a little sand in your face, man that is a nice chunk of bog.
Cheers GB![]()
Holy inches of bondo Batman!!
Great progress Bret!
20180423_192450 by bjohnson388, on Flickr
20180426_095943 by bjohnson388, on Flickr
20180426_095946 by bjohnson388, on Flickr
20180426_114212 by bjohnson388, on Flickr
20180426_114219 by bjohnson388, on Flickr
20180426_115114 by bjohnson388, on Flickr
20180426_142758 by bjohnson388, on Flickr
20180427_131116 by bjohnson388, on Flickr
20180427_131109 by bjohnson388, on Flickr
20180427_131951 by bjohnson388, on Flickr
20180427_131956 by bjohnson388, on Flickr
20180427_132445 by bjohnson388, on Flickr
20180427_132936 by bjohnson388, on Flickr
20180427_134916 by bjohnson388, on Flickr
20180427_135553 by bjohnson388, on Flickr
20180427_151150 by bjohnson388, on Flickr
20180428_174851 by bjohnson388, on Flickr
FB_IMG_1524967751832 by bjohnson388, on Flickr
FB_IMG_1524967747486 by bjohnson388, on Flickr
FB_IMG_1524967739357 by bjohnson388, on Flickr
20180428_163506 by bjohnson388, on Flickr
20180428_163504 by bjohnson388, on Flickr
20180428_163459 by bjohnson388, on Flickr
20180428_173539 by bjohnson388, on Flickr
20180428_173543 by bjohnson388, on Flickr
20180428_173548 by bjohnson388, on Flickr
20180429_100024 by bjohnson388, on Flickr
20180429_100029 by bjohnson388, on Flickr
20180429_100036 by bjohnson388, on Flickr
20180429_140746 by bjohnson388, on Flickr
20180429_140800 by bjohnson388, on Flickr
20180429_140751 by bjohnson388, on Flickr
20180429_140804 by bjohnson388, on Flickr
20180429_140829 by bjohnson388, on Flickr
Bret, I had two questions after reading your post.Saturday morning had my oldest son MDA muscle walk at the mall. Love this little man. Rare photos of me in my post.
He is supported by the local High School Honor Society who come to the walk and pull the firetruck contest you get entered into if your team raises over a $1,000. This year Team Nicholas Ray raised $2,950. The most we have in the 7 years we have been a part of the walk.
His teachers from school even came to support him.
Bret
Wow, you were going full bore this weekend, lots of good progress! You know if you make the trek to Nebraska you have to stop by at some point, I'm right off of I-35.
JB
He literally is right off I-35, about two miles and no stop signs (traffic lights don't exist there.
Great pictures of your son and the walk. There's the most important part of your life, but you know that.![]()
First, who or what caught your attention at that moment or are you just looking for an escape route?
Second, according to Amazon I saved money on a recent purchase. Rather than buying another tool, is there a way I can add $50 to help Team Nicolas Ray reach an even $3K?
Bret great save on the fender. Thanks for posting the rebuild of the wing window.
Great to see the support for you son and your family.
Dwight
Looks like a fun day for your son.
So is truck called porky pickup. You’re making it look pretty good.
DSCN0447 by bjohnson388, on Flickr
DSCN0445 by bjohnson388, on Flickr
DSCN5900 by bjohnson388, on Flickr
scan0004 by bjohnson388, on FlickrBJ: looks like you are making great progress on your truck and keep up the good work. looks like the fundraiser was successful and looks like your son had a great time.
i'm still trying to get my shipper to get the package together for you and hopefully i'll be ORGANIZED soon so he can.
cheers
Bob: I know you aren't the Devil, but man you do catch the DETAILS. WELL DONE
and maybe BJ has an answer.![]()
Aww, Bret, it just needed a coat of paint. I'll wager the fender had the Bondo in the fall of '81 so you're not really getting it back to like it was then, are you?
Glad ya'll met your goal. Next time, give GJ a chance.
20180501_191117 by bjohnson388, on Flickr
20180506_093240 by bjohnson388, on Flickr
20180506_204437 by bjohnson388, on Flickr
20180506_202858 by bjohnson388, on Flickr
20180506_202906 by bjohnson388, on Flickr
20180509_152838 by bjohnson388, on Flickr
20180509_152914 by bjohnson388, on Flickr
20180509_190944 by bjohnson388, on Flickr
20180510_091222 by bjohnson388, on Flickr
20180510_091617 by bjohnson388, on Flickr
20180510_091623 by bjohnson388, on Flickr
20180510_093804 by bjohnson388, on Flickr
20180510_101731 by bjohnson388, on Flickr
20180510_105446 by bjohnson388, on Flickr
20180511_185639 by bjohnson388, on Flickr
20180511_192100 by bjohnson388, on Flickr
20180511_192054 by bjohnson388, on Flickr
20180511_192236 by bjohnson388, on Flickr
001 by bjohnson388, on Flickr
FB_IMG_1526087978199 by bjohnson388, on Flickr
FB_IMG_1526087989871 by bjohnson388, on Flickr
20180512_193208 by bjohnson388, on Flickr
20180512_193219 by bjohnson388, on Flickr
20180513_095143 by bjohnson388, on Flickr
20180513_155754 by bjohnson388, on Flickr
20180513_104215 by bjohnson388, on Flickr
20180513_094012_ID_tOqGA7mtMiCYmt0DBPbUYA== by bjohnson388, on Flickr
20180519_105919 by bjohnson388, on Flickr
20180519_125356 by bjohnson388, on Flickr
20180519_125715 by bjohnson388, on Flickr
20180519_091845_ID_qEdCCjxSPcCR2RkComt1Mg== by bjohnson388, on Flickr
20180519_093718_ID_M3O0nyY9PM2zpKWMGdgEmA== by bjohnson388, on Flickr
attachment-93 by bjohnson388, on Flickr
Screenshot_2018-05-06-08-38-59 by bjohnson388, on Flickr
Screenshot 2016-04-21 at 8.19.02 PM by bjohnson388, on Flickr
Screenshot_20180428-205100 by bjohnson388, on Flickr
You owe it to those two boys.Good to see them rolling down the street. But that Caprice needs 20" wheels to fit in down there.
I love the wood side boards but around here you put the wood on the inside of the stakes.
Nice hammers! Just a tease shot though, I can't see much of the handles.
Cupcake production was impressive to say the least!
You'll get used to the rabbit odors.You owe it to those two boys.
20180520_135001 by bjohnson388, on Flickr
20180520_135004 by bjohnson388, on Flickr
20180520_140830 by bjohnson388, on Flickr
20180520_140856 by bjohnson388, on Flickr
20180521_155826 by bjohnson388, on FlickrBret, I'm so sorry. Time to start the search for icemaker 0.Uh-oh! Looks like you have the GJ icemaker virus.![]()
BJ: your truck just keeps looking better everytime i look at your thread so keep up the great work and IT WILL BE FINISHED SOME DAY SOON.
sorry i've never owned a fridge with an icemaker and even plumbed for one when I remodeled our kitchen 20 some years ago. I need to remodel the kitchen again cause after raising 5 kids and their friends and ours it needs it and I'll probably still plumb in an ice maker pipe just in case we sell or maybe get lazy and buy a fridge that makes ice. we've never liked the taste of the ice cubes and i use frozen old A&W glass mugs for my ice tea.
carry on and i'm still trying to chase down that shipping guy to send you some wood scraps for your little projects, but he's MIA at the moment cause he says he's moving his STUFF.
we have wild rabbits in our neighborhood and probably cause some pets were left out. sadly my cat takes care of a lot of them cause she might only eat one brand of tuna wet cat food, but if the store sold fresh rabbit I bet she'd love it. best of luck with yours and hope your boys and family love it and keep it inside away from the cats and big birds flying by.
20180522_120714 by bjohnson388, on Flickr
