signcrafter
- Joined
- May 9, 2012
- Messages
- 12,365
I know this has been covered a ton and I've read most of them but have a friend's truck to do with the dreaded 3 valve plugs that won't come out. It's a 2008 F250 5.4L with 9x,*** miles. I know the standard is the lisle broken plug tool and that is what I was going to order, https://www.amazon.com/dp/B00267PZUK/?tag=atomicindus08-20. But saw a different lisle kit for more money and more tools, https://www.amazon.com/dp/B00SQ4FSN6/?tag=atomicindus08-20. Then there is the OTC kit that is supposed to prevent the plugs from actually breaking so you don't need the removal tool, https://www.amazon.com/dp/B00C6R1P6I/?tag=atomicindus08-20.
So if you had to do plugs with a 9x,*** miles that have never been changed which tool would you buy?
Second question, I've read to use a 3/8" impact. I don't have my air compressor with me, have 5 of them but didn't have room to bring one back with me this time. I could probably find one to borrow if needed. But, I have a new M12 hex impact that I can use a 3/8" adapter for a spark plug socket on. This the newer one I just bought after my last one took a **** so it's compact and has decent torque. Will this be enough and also will it fit? Or do I need to order the 3/8" M12 impact? Or are both those too big and I need a 3/8" nano or compact impact to get the plugs out and borrow an air compressor to do this? Just want to make sure I have an impact that will fit and get the job done before I start this.
