The VISES of Garage Journal
va.grouseman
Southern-Central VA.
Acquired this Wilton vise 940 stamped"Acme Tool New York" a few years ago and just wondering if anyone has one or any info on them. Mine has 12-50 on the slide as the manufacture and warranty start date. I haven't seen many of these around, thanks gg54
Garageguy, I found a couple of those.---You don't see them pop up too often anymore.---I don't think they made a lot of them.---That is a nice one you have.---Hang on to it.---Mine are dated 47.
MayerMR
Dallas, Texas
Oh the humanity!
But in all-seriousness, while I'd hate to see an older, well-made vise subjected to such silliness, I can't help but think a Starett or Wilton wouldn't explode in such as fashion.
Gerard
Oh the humanity!
I was surprised by how much "give" the jaws seemed to have before they actually snapped, since the vise looks like one that would be made out of cheap gray iron.
rumb
Latvia
Drop forged in Germany. This model was produced between 1936 and 1948.
Ball bearing on spindle, double start threads, slop adjustment from bottom, felt dust covers to prevent dirt! And YES, its made ~80 years ago.
PS 125mm jaw width and opens ap to 135mm
gman007
West Michigan
What are double start threads?
Like dkroth stated in a multi thread two OR more threads start simultaneously at the start point.
Now considering that the lead is the total distance covered in one revolution (and pitch is the distance between threads), for a single thread lead and pitch are equal. For a two start thread pitch is half of lead and in 4 start pitch is one forth of lead and so on. So the advantage of multi thread is that it leads to a better mechanical advantage and the strength is increased by providing more number of threads.
rumb
Latvia
Yes, correct and it's operation very quick. One full turn of handle opens it ~10mm.
Every HEUER bench vice has double start thread, and RIDGID MATADOR too.
andgott
Athens, TN
I picked up this gorgeous hunk of American iron this week... $65 at a yard sale, but talked 'em down to $50-
A 3 1/2" Starrett Athol vise. It has to be the BIGGEST 3 1/2" vise I've ever seen! It's in good condition, too. Just needs some cleanup.
Shiftless
East Bay SFO
andgott:
Those Athol-Starrett vises are certainly top shelf! Nice find.
You might want to address whatever happened to this area.
It’s hard to tell from your one picture, but there seems to be some jaw damage in this spot.
andgott
Athens, TN
andgot:
It's missing the jaw pad on one side, but there is no damage to the vise itself. I'll just have to make new pads! A great project for the new milling machine that I have ordered...
Shiftless
East Bay SFO
:thumbup:
A nice set of aluminum jaws would be a good first project for your new mill.
If you want serrated hardened steel jaws you can always go to fellow GJ member KMScott. He has quite a few models in stock.
gman007
West Michigan
andgott:
It seems the jaw insert might be missing rather than an actual damage to the jaw.
Shiftless
East Bay SFO
I bet you’re right.
We seem to see a few vises with missing jaw inserts. How do jaw inserts turn up missing? None of mine just unexpectedly fall off and get lost. :headscrat
(I understand how pipe jaws get separated from exposed screw homeowner vises.)
CRSINMICH
Southeastern Michigan
Speaking of homeowner's vises, I just picked up this Athol A 3 1/2 S for my Homeowner's Collection . Captive wrench and buttress threads. Pretty classy for a light duty vise.
chrisnazzy
Arizona
I've been watching for a good deal on a little Stanley vise for awhile now and I finally got one.
I actually want to get a couple of them and I've envisioned cutting the clamp off one to make a cool desk conversation piece / business card holder. So when this 741 popped up on eBay the other day for $20 and with the clamp already removed I jumped on the opportunity to buy it and not feel bad about cutting up a perfectly good vise.
I worked on it a bit last night and a bit at work today. I think I got it looking pretty handsome for such a little guy.
Before and after.20180526_090822.jpeg20180526_090641.jpeg20180526_161108.jpeg20180526_161052.jpeg
davethorik
Norka, Ohio
Nice score. I have a Starrett 923 fixed base 3" and it is surprisingly beefy for size. I can only imagine the larger models are monsters. What is the weight?
Starrett swivel bases are modular, they are just added to a fixed base. I believe yours would work on mine. However, I plan to find a butcher block top for my Kennedy side cab, and mount the little Starrett to it fixed.
gman007
West Michigan
Chris Very nicely done but then again all your work is always top notch therefore I am not surprised it turned great :beer: :thumbup:
Diesel Dan
TN
my Dake #4 floor model arbor press has arrived. 12 tons, 1350lbs of great American iron.
Went and looked at my arbor press.
It's a: atlas compound mandrel press #4 12 ton, looks very similar to yours. Took some pics but can't upload them.
Have some pics of my 2 bullet vises, Wilton 654 and a larger no named vise. Will try and post them sometime.
KMScott
Nice job Chris. It did not hurt my feelings when I cut off the bench clamp to make a more useful small vise. I have done several and like them even better then the little baby's made by Wilton. Copied the Parker swivel base design. Pretty awesome vises, the Stanley's are built pretty good, just needed a little thicker collar shim which I made out of Bronze.
chrisnazzy
Arizona
Thanks for the kind words Kevin!
Like I'm sure most of us do, I follow along with your posts religiously and I'm pretty sure I saved several of the pics you posted of those four little baby swivel conversions. In my book they were marvels of a master machinist!
Once I realized your restored vises were available to purchase on your site I was even more intrigued and someday, sooner than later when my pockets are a little deeper, I will buy one!
chrisnazzy
Arizona
Chris Very nicely done but then again all your work is always top notch therefore I am not surprised it turned great [emoji481] [emoji106]
Thanks buddy! You're always so flattering to me but the truth is I'm still experimenting and learning. Me being totally intrigued with these antique vises and being a bit OCD sure help though!
davethorik
Norka, Ohio
Those lil Stanleys clean up well!!!
I had wanted one forever but they were always broke or too much $$$.
I found this no. 743 on Letgo for cheap, and jumped on it. It was totally not broken, nothing missing, just rusty. I was so happy!
Then my dad sends me a text saying his electrolysis tank was ready to go, and I suggested the Stanley as guinea pig. It did a great job removing rust, I was able to read lettering on slide finally, and got another surprise... It was actually made by Stanley Rule & Level, so is no newer than 1919-1920 merger between SR&L and The Stanley Works, pre-dating the Sweetheart tools. I wish there was a way to date even more accurately, but I suppose I lucked out knowing what I do.
I think I'm gonna BLO the patina left from electrolysis, sure does look good imho.
CRSINMICH
1915 CATALOG PAGE Notice that they were selling Stanley Jersey and Victor Jersey vises and that Stanley had a stationary base model.
Razorhunter
Dan,
Yes, the older Atlas #4 is the exact same press as my Dake #4. The even older "Eames" #4 mandrel press is also the same press. The design changed hands a few times over the last hundred or more years, but has been with Dake the longest, and still is to this day. Parts are still readily available as well. How much was seller asking for the Atlas? I'd love to see pics. Email them to me if you dont care to post them here in the vise thread as I did lol
twertsy
Reedville, VA
Gents,
I swear I've seen this vise but I can't find a pic here, and don't see it (under Weathers) in the spreadsheet. Anybody got one that can post pics? James Weathers Vise Patents are below, but he had TONS of patents, many (most) for improvements in lifting jacks.
If any of you folks remember seeing one of these vises, please post a pic or point me to them. Thanks!! Todd
1884 US Patent: https://patentimages.storage.googleapis.com/53/f0/46/d510a95edce9b4/US296658.pdf
1894 US Patent: https://patentimages.storage.googleapis.com/01/37/c7/a6495f0a2b643a/US516288.pdf
1894 Canadian Patent: https://books.google.com/books?id=H...6AEINDAC#v=onepage&q="James Weathers"&f=false
1903 Canadian Patent: https://books.google.com/books?id=I...oAQhNMAY#v=onepage&q="James Weathers"&f=false
gman007
West Michigan
Dan,
Vises and presses are siblings :bounce: and personally I would also like to see some photos here (and I don’t think anybody would object to seeing an impressive old press here)
Ps I did enjoy photos of your Dakar #4 , thank you for posting them
Diesel Dan
TN
Dan,
Picked my atlas up about 15 yrs ago foe $165, divorce sale.
Pics are an issue because we can't get internet at our new house and cell reception is horrible, data very sketchy at times.
oneoldboot
Pa
Newbie vise guy question. . . .
I have been using linseed oil on my vises, but they are rusting. I put on the oil, then wipe off gently, as not to remove it all.
What should I use?
Thamks!
