bubinga
One of these days I'll fix my PC and get back into GJ full force. Until that time, I'm stuck with my phone's browser
Are you using the Tap A talk App.
Its made for phones.
Oh Yeah, 1005 better on a P/C.Yes I do but I like the bigger screen and other features of a pc over a phone but the phone works. I use the garage journal app.
Measure the ID of the column. If you have a 2 3/8” ID then get rid of the snap ring altogether. The snap rings are there for 2 1/2” ID columns on later models.
Again make sure you are using the right end of the column. The right side will have a machined inner bore and will have almost a shelf so the plug won’t fall in.
Here's some before pics.
Sounds like a start capacitor issue.
There should be however you need to dismount the motor unless there is a capacitor housing on the outside. if not there it will be underneath base, (unless its a starter winding motor)
Does anybody have any diagrams (mechanical) on an old Emerson Electric motor. My recent DP came with this 1/4 hp motor, and I would at least like to open up and lightly clean the contacts, etc and also replace bearings if I can find a drawing.
Emerson Electric 1/4 hp
FR: S60PR
Style: 1233 25419
RPM: 1725
Thanks.
Shelton: I have access to a 1/2hp motor from an old table saw, but for now I just want to get this one running if I can. I want to use the DP for smaller woodworking projects, so the 1/4 hp should be ok for a while. Thanks
That 1/2 on the table saw is probably 3450 rpm. You need 1750/1725 rpm for a dp.
I've seen and have some that are even slower are 1100 ish RPMS, and if its a 4 speed DP, that would be better for metal.
Took one end cover off of the Emerson motor. There was alot of old grease here, what I thought was 1 thick washer was really 3 of them, including a thin spring washer. I cleaned out the end cap bearing/bushing (a bit) in mineral spirits with a small brush. So is this showing a bushing with channels in it for grease? At first I thought the bushing was scored, but the channels are symmetric. And is that washer on the outside of the cover plugging a grease channel?
Thanks.
excellent explanation Pete, thanks. So does that washer come out easy? Would like to see and learn.
And it looks like I will be using a different motor after all (the comments earlier suggested that already).
Thanks again.
so do I drill/punch a hole in the center area of that washer and pull out to remove?
Oh my!I took the motor off my dp tonight. Here's details of what I found.
Wow! What's your plan going forward?
I would be tearing the whole thing down and checking out the rest of the parts before looking for replacement parts.
I took a leaf from FrankLee's book for my chuck key:
Hey JZiggy - do you mean to leave a link on your last thread?
