Craftsman Drill Press
F
FrankLee
seMI, 48317
Has anyone had issues with the pin alignment? Do I just need to bang it in there? It just doesn't seem to align properly.
I've had a couple issues with the tilt table, but not specifically with the taper pin regarding table alignment.
The first was on dp#24 where the tapered pin was missing from the table. The PO drilled and tapped the taper hole from the top and bottom and added a third tapped hole and bolt on the side of the table/tilt.
The second was on dp#25 where I could not tilt the table or remove the table from the support after the taper pin and the tilt lock were removed. I believe a previous owner drove the taper pin in too hard and too far which deformed the parts.
First, is the table support in the correct orientation relative to the table, i.e., is it upside down?
Second, do the table and table support appear to match? Does the shade of the paint match? It's possible that taper bores on mis-matched parts were machined differently.
The tapered pin should be tapped in first (not banged in) to align the table and then the lock tightened.
A couple more pictures with the table support may help.
honza.vosalik
Missouri
Upon inspection it appears that I put the table clamp upside down. I'll fix that first before trying to figure out anything else.
I have quite a dilemma with the paint though, especially the front of the table has a lot of surface rust and original paint is gone, so I'm not sure if to repaint or not.
The table and base surface cleaned up pretty nice.
honza.vosalik
Missouri
Has anyone tried to match the original paint when repainting? Do you have the paint numbers? Did you have to have a custom paint made? How many spray cans for one DP?
It's funny how the original paint looks more blue at the place where it was covered while the faded turned towards green.
Redlig
Jacksonville, FL
Hey guys this may be a dumb question but recently got a drillpress and plan on refurbishing it. I know this ***** but the only pick I have of it before disassemble. Im terrible at pictures also one of the serial number. Does this mean it is a 103 model?
sheltonfilms
That’s a part number. But yet the 103 does mean it’s a King Seeley. The full model number is on a plate on top of the floor stand right in front of where the column inserts into the base.
Redlig
Jacksonville, FL
Cool ordered some parts for it. Going to mess with it while I wait on electric for the garage
F
FrankLee
seMI, 48317
I hope I'm wrong, but I think that quill/spindle assembly from ebay is from a 13-1/2" Craftsman 80 drill press. I believe yours is a 15-1/2" Craftsman 100.
That ebay seller has a bunch of other Craftsman 80 parts in active listings.
What's wrong with the original quill/spindle?
I hate that we can't see full completed ebay listings any longer (unless there's another way).
sheltonfilms
What part are you looking for on the completed listings? I just searched “craftsman drill press” and then filtered by sold items. Then I clicked on it and there is a link to see original listing.
This is a Craftsman 103 drill press quill spindle w/ 1/2 inch drill chuck & key. All in fine condition w/ smooth bearings.” Is the description.
What’s the difference between an 80 and 100 quill and or chuck? I know my old 80 (actually “100”) has a 1/2” chuck but my floor 100 has a 5/8” chuck.
F
FrankLee
seMI, 48317
I see the list of completed items, but when I click on it, I get "The listing you’re looking for is no longer available. Check out this similar item we found for you."
I just figured it out... the word "listing" in the above message is a link to the original listing. That just started for me a couple weeks ago.
The 80 quill and spindle are shorter than the 100/150. The chuck is the same.
If you have a 5/8" capacity chuck on a 100, I don't believe it's original.
sheltonfilms
Just went out and checked again. It’s 1/2” my bad. Don’t know why I thought 5/8”.
Redlig
Jacksonville, FL
The one im working on has a bent spindle. Oh boy.....hopefully I didn't just buy the wrong thing. The listing said for a 103. Please tell me I didn't screw up :sad:
F
FrankLee
seMI, 48317
No, you didn't screw up, the seller did.
I checked last night... the quill for a 100/150 has 20 ground gear rack slots. That one has 16 for a smaller Craftsman 80.
The seller does not know what they're selling and you can easily win a dispute. It'll be a pain, but you should get most/all of your money back.
Redlig
Jacksonville, FL
Well I appreciate the help. Well guess I still need a spindle still haha anyone need a spindle for a craftsman 80 apparently
F
FrankLee
seMI, 48317
Will it still fit just be shorter
It will fit, but will likely not work well. It may work for shallow feeds, but will likely pull out of the spindle pulley for deeper feeds. If it does pull out of the pulley while running, the feed return is going to be ugly when the pulley is spinning at 600 rpm and the spindle is at 0 rpm.
I've never tried an 80 quill/spindle in a 100/150. I'll have to post some comparison photos and dimensions of each size.
Here's a quick picture of a quill/spindle assy from a 13½" dp next to a quill/spindle assy from a 15½" dp. I don't have all measurements yet, but the diameter of both are 1-5/8".
I don't think that's an option. Many of the 80's had sleeve bushings up top, and the 100's I believe were ball bearing.
Just because the MFG is the same dose not mean the parts interchange. Ford truck tire on a focus? I don't think so...)
sheltonfilms
The sleeve bushing presses were the 12 1/4” presses without the headbands. The 80/100/150s had ball bearings.
Only difference I’ve noticed between 80 and 100 bearings is my 1947 80 (actually called 100 in 1947) had single side shields where my 1956 100 had double shielded bearings. This may have been a change through the years though.
honza.vosalik
Missouri
I had a custom paint made for the Craftsman drill press to match the original paint. Hoping it will turn out good :)
F
FrankLee
seMI, 48317
That looks like a real good match! I'm looking forward to seeing your completed paint job.
Please post more details; where did you have this done, how much, do they have sheen options, etc.
BlueHeart
Traverse City
Very cool find indeed! I've been meaning to ask our paint supplier here at work if they could do the same. If so, maybe I can bring some down with me when I visit.:thumbup:
poplaski
Greensboro NC
Re: Craftsman Drill Press 150 (130.24500)
Just purchase a Craftsman 150. Great site. I have a lot of reading and catching up to do. Two questions at first. Can't figure out what the two
holes are at the top front of the drill press. One on either side just below the name plate. Second, does anyone have a hub for the handles and one
handle. Previous owner decided one handle was in the way and cut it off instead of unscrewing it??? Now I cant get the cut of threads out.
F
FrankLee
seMI, 48317
Hello and welcome!
1) I believe you're referring to the holes for the spindle pulley retaining screws. Check this post:
https://www.garagejournal.com/forum/showthread.php?p=4771515&post4771515
2) Is it possible to cut a screwdriver slot into the feed handle stub?
If you haven't discovered www.VintageMachinery.org yet, here's a scan of your owners manual. http://vintagemachinery.org/pubs/222/2785.pdf
Let's see some pictures!
Dorsey
Valrico, FL
If you have access to a MIG tack the hole of a fender washer to the stub, then tack a nut to the fender washer and use a wrench to screw it out. You may even be able to use epoxy if you dont have a MIG if the stub is not in too tight.
honza.vosalik
Missouri
I got up early and took an extra trip before work this morning...
Came with a Dunlap 1/3hp motor. There's also something wrong with the return spring, will need to inspect later.
honza.vosalik
Missouri
A varislow unit that looks in good shape... you **** ! Did you get it for a you **** price ?
$200 bucks. So not way too cheap, but well worth it I think. I'm not really sure what the Vari-slo is worth, but that was the only reason why I bought it!
At this point I'm not sure yet if I'll move the Vari-slo on the 100 DP I'm restoring right now or keep both. This 150 is pretty cool and nice looking too, but do I really need three DPs??
poplaski
Greensboro NC
Finally got the broken threads out of the hub. Come to find out, there was
a broken piece of screw extractor in there. Finally drilled it out with this thing called a Rescue Bit that is designed to drill through extractors.
I am now in need of one handle with a Burgundy knob. Does anyone have an extra one for sale?
lafester
Northern CO
Hard to say... Never seen one for sale!
I think you did fine.
Sent from my moto x4 using Tapatalk
lafester
Northern CO
That's awesome. I see them on eBay all the time.
Smokeshow69
If you end up moving a varislow assembly or even pieces, please let me know. I need a control arm and gauge and the arm that goes to the first pulley. FYI your new purchase is not quite a you **** but is fairly close in my opinion!
honza.vosalik
Missouri
Smoke: I can take pictures if that helps anything.
Something is not right with the very front pulley, I can even feel it when turning with hand. Need to take it apart and inspect.
honza.vosalik
Missouri
I made some progress on the Craftsman 100 DP restoration, the paint turned out really great.
I misplaced the spacer with the nut cut out that is used to hold the head frame on the column (Headstock lock - part #18119). Really hoping I find it! For now I'm going to use the part from the 150 which doesn't have the nut cut out but has a thread instead (Headstock and Table Lock - part #18121), which will work just fine. If anyone has an extra or would be willing to help me reproduce one (I don't have the machinery), I'd be grateful.
