3rdgendslmech
At some point this week or weekend come hell or high water (high water is more likely) I'm going to run power to my barn. I'm using 1 1/2 pvc. I've only got about about a 4-5 feet to tie into the existing pvc to the right of the meter.
I'm having mixed feelings about where to enter the house at. The main panel in the house is flush mounted and behind the meter box.
Option #1 is to try to go right below the SEU cable from the meter. I'd have to put an LB, box adapter and access panel on the interior wall, which I'm fine with. The only thing is the two LBs wouldn't be perpendicular to the wall. The knockout in panel is a little to the right (looking at the panel, inside) of where the SEU enters the panel putting it at a little bit of an angle.
Option #2 is to come straight out of the exterior wall and just to the left of the meter feed. So the conduit would be passing in front of the meter's conduit. Not sure if that's legal or not but IMO it kinda would look messy that way.
Here's the pic so you guys can see what i'm talking about:
