Howdy neighbor! Yea it was roughly 8 days said and done.
So you're using them for the plan and material? And you're doing the labor yourself?
Yeah I purchased the material from them and am building by myself. It’s a 40x48 with a 40x12’ lean-to to serve as additional parking.
I see you have electrical installed. What did you do with that? Pull a sub panel off the house?
As far as interior goes, I’ll be doing plywood primed for the walls. Not yet set on ceiling liner yet but leaning towards steel ceiling liner panel.
The shop will be spray foam insulated on the walls at the very least and likely r60 blown in the lid.
I’m going with hot water radiant floor heat and the shop will have its own 500 gallon propane tank. I plan on spending a lot of time in the building so I want it as comfortable as possible.
