Howdy from Colorado
Kwando303
Colorado
Just had Cleary build a 42x56 building on my property in Colorado. Just stopping by to say hi. Looking for ideas on how to finish the inside. Here is a quick time lapse of the building going up.
jmlcolorado
Elbert County, CO
Ha!
Saw your video. We’re closer then I thought. I about 2 miles back on sun country. I saw your building go up. Those cleary guys sure don’t mess around.
K
Kwando303
Colorado
Howdy neighbor! Yea it was roughly 8 days said and done.
So you're using them for the plan and material? And you're doing the labor yourself?
jmlcolorado
Elbert County, CO
Yeah I purchased the material from them and am building by myself. It’s a 40x48 with a 40x12’ lean-to to serve as additional parking.
I see you have electrical installed. What did you do with that? Pull a sub panel off the house?
As far as interior goes, I’ll be doing plywood primed for the walls. Not yet set on ceiling liner yet but leaning towards steel ceiling liner panel.
The shop will be spray foam insulated on the walls at the very least and likely r60 blown in the lid.
I’m going with hot water radiant floor heat and the shop will have its own 500 gallon propane tank. I plan on spending a lot of time in the building so I want it as comfortable as possible.
jmlcolorado
Elbert County, CO
Hey brother.
Don’t mean to spy, but I noticed you had a pole and transformer added to power the shop. Do you mine sharing how much they charged you for that?
