Don't break those Edsel Tail lights. Guy posted a pair today......
$950
i had seen those on the Hamb, luckily his are in alright shape, the driver side has a chip in one of the corners but I think he found a pair of lenses on ebay or an edsel facebook page and grabbed those, so hopefully he doesn't need a new pair.
Semi productive week off, not as much as I would have liked to get done but some work is better than no work!
I needed to start the inner and outer rear rocker repairs before I could get the flat floor pans welded in since it gave me a lot more access to the back side of everything with the floor out. The cheap eastwood bead roller is earning its keep, though it might need some reinforcing with stuff like this, but honestly if I can get what needs to get done on the buick, and the bead roller is complete trash afterwards, money well spent
20180622_155733 by
Dan Haas, on Flickr
make it roundish
20180622_162225 by
Dan Haas, on Flickr
The wheel arch bead for around the rear fender and the door sill steps although the inner step will need a bit of massaging but i'll do that when I do the door sill corner repairs.
20180622_165642 by
Dan Haas, on Flickr
20180622_170437 by
Dan Haas, on Flickr
over the existing metal, just magnet'ed in place
20180622_170712 by
Dan Haas, on Flickr
20180622_170703 by
Dan Haas, on Flickr
20180622_170734 by
Dan Haas, on Flickr
20180623_155354 by
Dan Haas, on Flickr
20180623_175447 by
Dan Haas, on Flickr
20180623_170942 by
Dan Haas, on Flickr
Just a first pass, still have to make a filler piece or 2, fill some gaps and pretty it up a bit, but it should work well enough, and the passenger side should go a bit easier now that I have an idea of what it needs.
20180623_180822 by
Dan Haas, on Flickr
20180623_180813 by
Dan Haas, on Flickr
Also made the rest of the torque tube tunnel, though I think I accidentally deleted the pictures of it, got the tacked in and started tacking in the rear section finally
20180622_152654 by
Dan Haas, on Flickr
got in a 3rd Carter W1 574 carburetor, still need to find atleast 1 more for the set up for the straight 8, and made a handful of carb side flanges that i'll need to the intake runners. i'll end up buying the head side flanges I need since they are cheap enough that i'll be ahead buying them versus time spent making them.
20180620_170527 by
Dan Haas, on Flickr
20180617_125447 by
Dan Haas, on Flickr
Also stripped out the edsel floor mats and insulation to figure out what we needed for patch panels for it. I was pleasantly surprised, with the exception of a small area around the gas pedal, the front and under the back seats were really good, and we already knew the rear foot wells were junk, so no surprises there. There are panels available for the similar year fairlanes so we will be going that route, though they are a little spendy
20180617_190005 by
Dan Haas, on Flickr
20180617_183500 by
Dan Haas, on Flickr
