Wamsutta
For the sake of discussion, let's refer to the top of a socket as being the square drive end. You guys with the Hansen socket trays will probably agree. OK now ... let's pretend for a second that a chrome socket has no detents, what's going to keep the socket from traveling all the way up an extension; the round section, correct?
The square drive end of the socket is prevented from traveling all the way up the extension because it runs into the round section. If the entire extension was a square, then the circumstances might be different.
Now ... wouldn't it be nice if the little spring loaded friction ball of the extension was to center itself into the scooped out detent at the same time as the square drive stops at the round section?
In order for that to happen, the scooped out detent needs to be positioned inside the square drive in such away that the friction ball centers into the detent at the exact moment that the socket stops at the round section. If the detent is too far up, then the friction ball of the extension is going to travel passed the detent before the socket comes to a complete stop at the round section.
If the detents are too far down in the square drive, then the socket will come to a stop at the round section of the extension before the friction ball of the extension has a chance to engage with the detent.
If any of you guys can explain it better than I can with words, please do so.
