PelicanPines
What if your extensions are not round... some of mine are hex...
GearWrench may make them that way to work better with a wobble-end, but I don't know because I don't have any wobble extensions.
What I do know for sure is that my Snap-on and Proto sockets are timed so that when the friction ball is fully centered in the detent, the socket is also fully seated up against the stop. It feels like a rock solid connection when the socket is sitting fully square against the stop and centered in the detent at the same time.
Can you hear the click every time you move the socket between the fully centered detent position and the full stop?
Yes, it makes a nice audible click if I push it down, but I'm almost certain its not suppose to sit there, and instead it returns often by its own will or with the help of my finger, up a little to a more natural resting point. Also tested again with my other sockets and different extensions, and most seem to do this
That tells me that all the long time American tool manufacturers have accumulated the experience in knowing exactly where to place the detents.
Huh...I never noticed those detents. I've been hammering the extension into the socket all these years.
The Apex goofy double detent will lock up My Snap-on wobble extensions.... They are a pain in the rear to remove from My Snap-on and Proto ratchets.. A screwdriver should not be required to remove a socket from a ratchet. I like Normal sockets; so I avoid purchasing any more USA Apex double detent sockets.
It's pretty evident the detent indentation on the Gearwrench sockets are meant to make them work even better with a wobble extension and I see no downside to a little play or that the socket can be pushed a bit further past the ball detent.Those who see this as a no issue just don't get it. Wamsutta has outlined a very important factor in socket design that is rarely done right. Its simply just the location of the detent. I often get a sliding T, put whatever length extension on I need then a socket or sometimes my Stahlwille ratchet adapter in between the socket & extension to end up with a seriously capable T nut driver/ratcheting nut driver. When the detent is located poorly the whole assembly looses fitment & becomes a wobbly unsolid mess of tools. Detents located correct it feels solid like all the pieces are one tool. This tip/knowledge really helps when deciding what to buy. I hate it when I put a GW socket on a ratchet and push it all the way on then it pops out and sits in no mans land wobbling around....its crude.
MERK is that you?
The snap on sockets with the white towel photos sure look like MERK photography
A similar issue about detents was raised more than a few years ago and the author wasn't fond of how Gearwrench extensions fit in sockets either.![]()
I use tools all day every day and see the loose fitment as a plus. I don't even recall last time I used a regular extension for anything any more. I had to dig to find one just to do the measuring for this post.
I always reach for a wobble-plus extension. They work better. They save so much time. They're one of the greatest advancements in sockets and ratchets in my lifetime IMHO.
Yeah, I think my 1/2" extensions are what you describe as 'wobble plus' where they wobble and also if pushed on further lock into a normal straight position. I agree, very clever and function well. I would not buy regular wobble extensions now days and need 2 of every length, drive size etc.
