Best 1/4" quick-change hex X 1/2 Socket Adapter
redmed
I keep breaking 1/4" quick-change hex x 1/2" drive socket adapters. I just bought a Irwin 1837573. It has the shortest shank I could find. I'm hoping with a short shank the Irwin 1/4" quick-change hex x 1/2" drive Socket Adapter will hold up. Is there a BEST 1/4" quick-change hex x 1/2" drive Socket Adapter?
PR1Gneon
My Milwaukee shockwave adapters are holding up well.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Negen
Seatltle WA
133W-70 koken hex to wobble 1/2
135W-60B koken hex to 1/2
BD023 169 koken 3/8
These I use at work with battery impact wrenches and have no issues.
We use the cheaper ones to weld to 7/8 extra deep sockets. Lots of the other guys who have been rehabbed away from gj just use harbor fright hex adaptors. At home I use the 3/8th above with my fien drill no issues. At home I use mainly with t-20 or t-15 sockets from koken when making furniture or fences. Koken has a few lines of these made different with different part numbers but I can't tell the difference.
Sent from my G8141 using The Garage Journal mobile app
rmsg0040
Toronto
What size sockets do you run with the adapter
I use 1/4 hex to 3/8 square up to 15/16 socket
R
redmed
I use with my Milwaukee M18 Fuel impact driver to remove/tighten vehicle lug nuts. The M18 produces just the right amount of torque. But every wimpy 1/4" I have tried so far has twisted apart within a few weeks use. I attach the hex driver to my 1/2" deep well impact sockets.
R
redmed
BD023 169 koken 3/8
Yeah Negen I'm in the U.S. The "135W-60B koken hex to 1/2" looks very much like the Irwin 1837573 I picked up from Lowes so I have hopes it will hold up.
Negen
Seatltle WA
Milwaukee also has a twister or maybe sidewinder I forgot that I guess is made for these type of 1/4 impact hammers. I have one that is used quite well. We use them for anchor type bolts in 4x4s or securing 600lb machines to bases. I am not sure if this is as much stress as lug nuts or not. It is one of those hard metals vs soft metals issues I suspect. I do not know much about metal types but s2 steel hex bit of any type seem better to me than cr-v.
lamesalegend
Easily Grey Pneumatic's adapter. I don't have a 1/2 impact so Ive gone thru plenty of 1/4 hex to 1/2 adapters. I know I using the wrong tool for the job but I use what I have right now.
The Grey Pneumatic adapters have held up the best plus they are shorter than some others. Don't get me wrong the Grey pneumatic will still break, they have just been better than the Dewalt and Irwins Ive had in the past.
http://www.gpsocket.com/products/product.phtml/1412HA/?popup=1
http://www.gpsocket.com/products/product.phtml/1403HA/?popup=1
potato
these hold up as well as any other and they are less than a buck for all 3 sizes with coupon.
R
redmed
I do not think any of them is going to not break.
You may might want to buy the Bosch 18v 1/2 with the 1/4 impact adapter - then you only need a 1/2 to 3/8 adapter.
https://www.lowes.com/pd/Bosch-18-v...s-Impact-Driver-2-Batteries-Included/50149882
I already have enough impact drivers. All of them are red and they use the same M18 or M12 batteries and I want to keep it that way. Some of the drivers are too weak for lug nuts and some are too strong and bend rims the M18 Fuel is just right.
sk farmer
nd
this is a prime example of using the wrong tool for the job. you need a 1/2 impact or at least a 3/8 and adaptor. using an adaptor in a pinch is fine, get the job done. using it enough that you are breaking them on a frequent basis...........get the right tool and you will have no issues.
i mean seriously.......would you use a 1/4 inch square drive ratchet in that application and expect it to hold up?
CR888
Troof.:thumbup:
CJM8515
quoting again..
sk farmer
nd
this statement is actually wrong as well.
you have too many of the wrong impact drivers and not the one you actually need. color of the tool or battery has nothing to do with it. even if you are stuck on red i am positive there is a red impact that would meet your needs.
