If you go to the public profile link on the members ID section you'll see that I'm a............
Thomas
Do those windows just pop out?
I am not sure, but losing a window like that, at altitude, could be indicative of a problem.
I wanna see a picture of the pile of stuff you saved.........
BB767....was this posted on another web site a while back?.....Shop Talk or....???? I recall seeing the "Three on the tree" before. And, as if you hadn't heard this before, "Nice Job".
Looks great, definitely a lot of work.
Question, Did you have any environmental issues buying a property that stored petroleum products?
Love Google Earth - found it.
Hmmm... The small AC unit might also be a give away...
I do have to say that this is the most awesome build I've seen. I like this much more than the multi-mega new builds... Kudos!
Paul
That is really a Renzor furnace hanging from the ceiling in the background. It´s one of three as each room has it´s own heater and thermostat. I have no A/C in the shop. There are loads of shade trees around, plus all the concrete in the floor, and walls keeps it naturally quite comfortable in summer and I put heavy tinting on all the windows to cut down on heat transmission and block UV rays to prevent fading. I also use two dehumidifiers to keep the humidity at less than 45%. Almost everyone who comes in there in summer remarks how nice the A/C works before they find out differently!
Thomas
Thomas, thank you - please keep posting, so far this has been a wonderful flight.
Kind of off thread here, but do you like the 767 better than the 757? I always thought the 757 was a sleeker, sexier looking bird, but driving - can you tell any difference when you get to that size of a/c? I'm a stick and rudder, seat of the pants guy myself, but I thought it'd be a rush driving a 757.
I'd love to stop in for a visit some time - any powerlines in the way that would prevent dropping the Stearman in on Roosevelt Rd? Appears to be some on the south side of the road there. OK, just kidding about the road, can I land in that field south of you there?
I'm with you on the radials, but you have to admit, ZRX61 has a point about the Rolls - that is a magical sound! (BTW ZRX61 - nice TigerCat! Very few of those flying!! Maybe 6?)
Window washer?
And finally, what's with pilots and cool stuff, I know a few and they all have cool stuff (cars and tools)?
Me too!!! I'd have just loved to help you haul stuff off. Is there anything you truly regret having hauled off. I know how it is when you make a find, you go for the gold and sometimes say to yourself later 'man I can't believe I didn't save that'
Was the parts washer too far gone to save? Great job on the Pepsi Machine!!!
Don't know how I missed this pic but please tell me you're leaving it where it is? That is so cool it just has to stay there.![]()
Gorgeous shop, it's always great to see restorations. Sounds like you've got a great flying gig going, were you prior military?
Wow, two days + without a post. I'm having withdrawls! QUOTE]
I have to admit that I miss doing the posting as well. Should be home shortly and we can continue. I´ll be off for the rest of the month so I will be able to get much more out. I have more before and during pictures, some of the 1958 addition being built, a series on construction of the current benches, the coal room transformation, go karts that were made there and the jig used to make them, a ´powered vehical´ ( I just don´t know what else to call it) that we made there around 1968 from various parts we gathered and welded up that included a 1936 Anglia engine, current shop details and photos, ´saved stuff´restored ´stuff´ and as they say much more. Thank you to all for the interest.
Thomas
What??? When did they start allowing pilots to play with tools?? LOL!
This is my week so far...
Back on this next week...
To fill out what was done on the wood wall replacement, here are some pictures to show how it was done. As you have seen the the wall across the front of the original shop was wood as was part of the west side. It was concrete block the rest of the way around the building. I decided since the wood wall was in such poor condition to replace it.The block also made the shop more secure and was better to prevent wind infiltration and keep heating costs down.
To start, temporary braces had to be fabricated to prop up the roof once the wood wall studs were removed. I had plenty of material on hand to make the bracing with! Seen here is that fabrication and note the old Lincoln welder in the background as well as the welding bench. None of the old welding rod left was suitable for the Lincoln welder so I used a modern one. I have since purchased good rod and the old Lincoln still works perfectly. For heavy metal it's hard to beat an old arc welder for good penetration.
This is the fab room mostly cleared out ready to remove the wall. See the grinder build into the wall on the right driven by a belt and old electric motor? I had plastic over the man door to prevent wind from coming in . This work was done in January and it was freezing most days!
The exterior clapboard has been removed leaving the wall studs. In the shadows you can see the cast iron welders bench and the trip hammer. They were just too heavy to move so they were left and we worked around them. It turned out to be a pretty neat picture with the old tools silhouetted like that I think. One of my favorites from the hundreds I took.
Here a clear picture showing the two walls that were replaced. The lean to that steel was stored in has been removed from the side of the building. New roof is in place, dry inside for the first time in years!!
Where the block juts out was a small 8' X 8' room that was where he stored his coal for the forge. Extending beyond that was the 1958 room addition. Also seen are the Terraplane with the tree growing through the steering wheel and beyond that the blue '57 Chevy and an early '60's red Ford pickup. Foreground left is part of the steel storage rack.
Here's the steel storage rack. Weighed several hundred pounds and we used a backhoe to move. Took a torch and cut it up for scrap.
Here the west wall clapboard is gone. We dug down to check how deep the footings on the original building were. They were good so block was laid on them. The brick mason was friend of mine for the last 30 years and really knows his stuff.
I eliminated the three windows on the west side and put one in on the south side. The shop sits on a small hill with a terrific view to the south. Those trees by the steel rack are hedge apple. They were planted all over the Midwest in the 1930's during the dust bowl to prevent wind erosion. Mine are are old but healthy. You don't don't see hedge rows much anymore. Period trees for a period building I think.
One of the reasons I thought the building could be saved was the concrete block on it was all solid. No cracks anywhere and straight as a string. I later found out that the fellow who laid them in both 1958 and 1962 ( same guy ) was old school. He'd soak each block in water before he laid it so the the block wouldn't soak up moisture from the joint too fast. Made for a better joint. It took time but it paid off. If the walls were all cracked and the joints in bad condition I'm not so sure I would have restored it. The roof was pretty bad but we only needed to replace a few deck boards. I caught it right at the turning point. Much longer and it would have been too expensive to repair. I do have more so stay tuned!
Thomas
