Cutting down a Vidmar box
royce
fairbanks ak
I have a few tall vidmar boxes to cut down to work bench height.
I've been reluctant to start, thinking it would be a lousy chore.
Needing to build a miter saw station, I got started and finished cutting one down.
It was a walk in the park, drill out a couple dozen spot welds, grind a few short welds on the inside of the cabinet, remove top, cut the sides and back down, set the top back on and plug weld the holes.
All tolled,it took less than 2 hours.
I did not reinstall the anti-tip mechanism, so that would add some time, if you wanted that feature.
If you need to cut one down, don't be scared like I was, it is really easy.
Royce
LXCam
Let me guess, when you're finished itll turn into a Optimus prime right?
Royce you make this metal stuff look toooo easy bud, keep up the great projects.
tarbellb
Oregon
Nice, just send one of those Vidmars to me, I will document how long it takes.*
* I get to keep the final product right....
southalabama
Brewton AL
Somehow I think that I could make your two hour job into a two week job and still not get the same results.
Good job.
lilredex
Toronto
Yes, what blade please?
And, take a look at this one too, it cuts like going through cheese.
R
royce
fairbanks ak
Thanks all,
The blade is a 48 tooth freud.
I will keep the scraps for other projects or for mounting a single drawer.
Royce
