My 30x40x12 progress
stioc
SoCal
Cool progress. I have a dumb question since the concrete is being poured after the building is complete- I'm not familiar with the pole barn construction methods. Are the building posts simply dug into the ground and the bottom filled with concrete - kind of like you do with the typical fence posts?
T
tpndrcn
They dug the holes 18" round and 6' deep I believe. Then they put a concrete cookie/footer in the hole and set the post on that and then backfilled with the post level. They then verified level again when attaching the girts.
Sent from my Pixel 2 using Tapatalk
stioc
SoCal
Ah ok, that's kinda what I figured and that was going to be my next question that if they filled the hole with Quickrete or something so basically the same process as a fence post around here but just deeper into the ground. Thanks.
T
tpndrcn
Here's a few pics of the concrete all done! Can't get out on it yet because of the sealer but it's looking nice!IMG_20180624_165341.jpegIMG_20180624_165337.jpeg
T
tpndrcn
Wanted to share some more pictures of my concrete and wiring progress. The concrete turned out fantastic , I can't thank my buddies enough for the good work! I wired an outlet every 8' and installed 8 out of 10 LED 4' lights that I bought on Amazon. I am extremely happy with the results. It's more than bright enough!
Here's the link to the lights if your interested:
Sunco Lighting 10 Pack - Energy Star, ETL - 4ft 40W LED Utility Shop Light, 4000lm 260W Equivalent, Double Integrated LED Fixture, Ceiling Light, Garage, Frosted (5000K - Daylight)
https://www.amazon.com/dp/B0748YTDMK/?tag=atomicindus08-20
1dfb502e41cf83c5d67dbacc1fdec7e0.jpg58b9f06339a4da695c1d52f157f3d908.jpg4c16b0b7d09a40e0e197dfbdf0affe15.jpg782d682789ed98446062f8a75ec3f109.jpga21d904f282afeeb8d77ac353a0c012d.jpg1f57e44a721ec5f9229ce93acf4af312.jpg6a445156bcfa3d4118bf885430445ccb.jpg
jarhead
Colorado, near Morrison
nice looking building
what is the black material between the tin and the outer shell?
we did a 24x40 years ago and I wish I'd used the laminated 2x6 method instead of pressure treated 10' posts. I also wish I'd built it allot bigger.
Bears Fan
Indiana
Great looking build! I will be following along to see how it turns out? I PM you about the heat! Go with a mini split in my opinion :beer:
