Morgan Vice Parts List
ed4banger
Virginia
Contacted Milwaukee for Morgan jaws, they sent me a parts list, which I'm trying to attach here, for anyone looking for parts. Looks like, if someone wanted to, they could assemble a complete new Morgan from the parts.
  • 2-1-2016 Morgan Vise Parts.pdf
Stuart in MN
Minneapolis
Looks like a useful reference, plus it has a good exploded diagram that identifies each part.
dgmpam
Madison, IN
Found an old Morgan Chicago vise at the local flea market with the only marking of 3-1/2 on it besides the Morgan Chicago. It has a toothed swivel base on it with a threaded rod down through the middle with a wing nut on the bottom. I think the rod goes through the bench surface and is tightened and loosened to lock and swivel the vise. I contacted the Morgan vise people and they said no one there had ever seen such a swivel base like it. Has anyone ever seen such a vise before?
E
ed4banger
Virginia
How about a picture?
Like this old yost?
dgmpam
Madison, IN
Here is the picture of the Morgan Chicago 3-1/2S vise for the above post. Not the best pic but all I have right now.
Shiftless
East Bay SFO
dgmpam:
It is sad that nobody at Morgan Milwaukee knows much about the history of vises. That method of fastening down swivel vises was very common a hundred years ago. Many if not all manufacturers used that system with a long bolt through a hole in your workbench tightened down with a huge wingnut or handle below the table.
I have an older model Prentiss Monarch vise with the through the bench mount.
Here it is in retirement sitting on a display shelf.
I have a Reed with that mount as well. (No pics...it was found in a dumpster frozen solid with rust and I haven’t worked on it yet)
Shiftless
East Bay SFO
Here is a Parker with a handle.
I’ll show the catalog page and my damaged little guy that although unmarked seems to be an awful lot like the Parker.
benchracer1
ramona, ca
The only part not shown is the part I need. there's a pin that holds the main nut in place. Is that a standard taper pin or a special part?..Steve
E
ed4banger
Virginia
Usually just an appropriate size soft steel rod will work. Morgan pin I'm looking at is not tapered except on insertion end for ease in starting.
