Miter saw station
royce
fairbanks ak
Got started today building a saw station.
My goal is to set it up with good dust collection and a fence with stops both right and left.
Started with some 1-1/4" particle board with formica and maple edge table tops, 2x4s and some 3/4 form plywood.
I sized the dust box for right and left miters with out considering compound cuts and ended up relieving the sides a lot.
I think I'll make some removable filler panels for when not making compound cuts.
Spent more time scratching both ends than working today, but still made some headway.
Royce
nutjob
NE, PA
Here's a pic of my setup. I used to have an extension table on the right that matched the left side but needed room for the belt/disk sander. I also find that I don't really need the fence on the right.
Kevin
LXCam
That's going to be a nice set up Royce. What size is that base cabinet, it looks huge! 60"?
kbs2244
This is a very popular project on the wood shop sites.
Lots of ideas to steal.
R
royce
fairbanks ak
KBS, I've studied a few of them on other sites, sawmill creek is great.
Chad, a pic would be great.
Made some good progress today.
Got the under table dust ports in, tables mounted and the roof on.
I cantilevered the roof, thinking I'll mount a light to the overhang.
Next up, end wall filler panels, telescoping table extensions, fences and end stops.
Royce
R
royce
fairbanks ak
Got the extensions done today.
Framed with 2x4s with polyethelyne slides
Made the leg out of garage door rail with a adjustable polyethylene foot.
Royce
R
royce
fairbanks ak
Thanks jeepinerdeep and toolfool,
Got the fences glued up today, I'll use unistrut for the stop track.
I think I'll face the fences with formica.
Royce
don long
southern california
Hi Royce
I've been wanting to tackle this kind of a project but haven't pulled the trigger yet. Thanks for the encouragement. Yours is looking great
Don
R
royce
fairbanks ak
Hello Don,
Not much of a plan on this one, just letting the materials on hand lead the way.
Glad you are encouraged.
Thanks
Royce
drewski
Mid-Tn
I'm a little pushed for space so I built my miter saw setup in a way that lets me move it around. I saw a setup similar to this several years ago, so I just built it to fit my needs.
R
royce
fairbanks ak
Great design Drewski,
I could not find any formica in the junk heap but did find some FRP and laminated that to the fences.
Also got the struts mounted.
Royce
R
royce
fairbanks ak
Got the stops made today and rulers let in.
With the way the stock fence needs to be moved outboard for compound cuts,the stops only have a 0" to 24" range.
I will make a longer strut to sandwich on these ones for longer cuts.
Royce
ddawg16
S. California
Looking good.....I think you're headed in the right direction....
I have an old Craftsman radial arm saw....and my compound miter is not a slidder....so I made a dual setup...common rip fence. Narrow boards I cut with the compound....wider with the radial.
Kinda tempted to get rid of the radial and compound and get a single slidder.....
On a positive note...I can cut a 16' long board anywhere I want to....
That reminds me.....I need to clean my garage.....badly.....
R
royce
fairbanks ak
Thanks ddawg,
Made the stop extension today, it worked out well, works on right or left side and has a range of 2' to 8'.
Has a simple mount that has a single sliding thumb screw to attach, takes only a few seconds to mount or take off.
The best part is it uses the same stops and curser as the short ones.
Also made a curtain out of some heavy cargo tarp, added a couple shelves and FRP side panels, a couple lags to hang the stops when not in use, drawers installed.
I guess it's done
Royce
ddawg16
S. California
Thanks ddawg,
I guess it's done
Royce
Hmmmm.....you are giving me ideas.....like I don't have enough projects
R
royce
fairbanks ak
The stop awesome. Always appreciate your creativity and ingenuity. Thanks for sharing.
Thanks ilovevocs,
I just realized a great side benefit to this system is that the stops act as a secondary fence and need not be removed to make a cut.
Royce
BWS
Mnts of Va
Just how we do it here;
Got 4 wood shapers and a router table.The RT gets used maybe a cpl times a year?It's on a mobile base.The mitre box is a simple torsion box with open front that fixture blocks get thrown into.Also,being open.... clamping fixtures/stop blocks is easier.It lives on top of RT.
Anyway,the few times we need the RT,just slide the saw system onto a table saw or big jointer temporarily. Good luck with your project.
nonhog
Arizona (Tucson)
Great thread! Lots of good ideas.
My thoughts are to add a side to the cheap HF bench instead of just putting the saw on the bench when I need it.
R
royce
fairbanks ak
Thanks BWS
Nonhog, good idea.
I had this saw on the bench and every time I needed it, I had to clear the bench, so that compelled me to do this station.
Royce
corvettecrazy
So many great ideas in this thread! I wish I had as much space as some of you to build extended tables.
ezridr60
Iron River, MI
Here’s a few photos of a saw station I made a few years ago. It has worked out pretty well.
LXCam
Excellent work as always Royce and the thumb screw (lol) is bad to the bone. Great job bud.
Now that's the most impressive wood working station I've ever seen. Do you have a thread with some more details?
R
royce
fairbanks ak
Beautiful shop EZ
Firstram, the curtains are two layers of 3" wide staggered.
They work nicely, thank you
LX, chain links make for great thumb screws.
Thanks all
Royce
