Show your new tool arrivals
krc328ic
Maine
Walking through Home Cheapo the other day and the pressure washer ended up in my cart somehow. Haven't used it yet, maybe today. The 18v blower I got cheap off the bay just for clearing pine needles off the deck quickly. It works pretty well considering it's size. By no means a replacement for my gas blower but decent for what I wanted it for.
PelicanPines
My wife uses one of those blowers for INSIDE the house... to knock the tumble weeds off the stairs and to dust some areas... she hates dusting but doesn't mind using power equipment.
NUTTSGT
Northern Central Ohio
Small hauls this past week.
5bZnFtu2XuOlhr-im73UhsQhvsTieu1QINXj_CxEoE-Cu_Xsigz7nHA0LEQEFG1M8oGDWENKUFnNCFac_KtAX_w3g1Hfb1KATSB919TCF-gDyf6KIqO2KNkPeSDR6-FiCOepKAVRDwp1Hx15x6x3mDZAP_fvx9St6uRdX_75hImz0_aUUsbAbOvEmDGW8rJLYwzwDKsr5VP4-lhYAn2UkvGhK6JjMMyaHDGlEQwmcWG3tY7KJaYnmbNZVeEGMdnB-3KoGBVK-T36-Zz4bBCYUGNxhS6YkQzlUvbKBvxzCudp9WwxyHf2aMpN5UZkv8AAKvBL7Tn4qk6H5voxNFyiqfxFzRd5nPtvMAFw6MP3iaXOzAeq-Pu4UNyk8ohU3cmIFTv5P_asWdDWY8tzj1XrMedSevn6WwdeuZ_-6wVf6n9Zp9ZYalb-0hjKwLDwnjXiIWOShAZHjdMe7o2xC5T1ScVuRtb3jfbiRO2okeMZtDOg-HBgPe9CCzzpq7hdJlkJOYk1g27TCDTy4qm5vhJdMzRcqGxNQt2_fEkrusB1Tuq-b_p1Zkgj85THqeY3wox_8NgjsXN2FSi0SYxjhx5Jg9lHM-GOIe-vOsVhEkQD=w1379-h921-no
Is it the picture or is that new tool all rusty ?
Motorman55
South Jersey
Picked up a few items from HF last week and put them to use right away.
1. Portland #63254 1750 Power Washer. Got it for $71.00 with 20% coupon.
2. Portland #62630 22" Hedge trimmer. Comes with a nice clear plastic bar shield that slide off and on. Got it for $30.00 with 20% coupon.
3. Cen-Tech #69465 Non contact infrared Thermometer. Got this for $5.00 with a special on-line coupon and purchase of $50.00 or more.
All the above tools worked great and have already paid for themselves. I took a pic of the on-line coupon with my camera for the Thermometer and they scanned it at the counter.
barrybeefburger
North of the GTA, Ontario
Oh! Which calipers will it no fit? Please share I am very curious. Thanks
The unit is rather large and doesnt fit alot of smaller calipers on the backs of cars, I have this and whilst it works great on the fronts of most cars the backs are a different story, it also doesn't "wind back" the piston so you need to use a cube or better set up.
Im still considering cutting mine down, IF i was in the game as a pro I would cut it down smaller and have the standard for all /most others
dodge610
North Canton Ohio
4cb405c14093d1b16282d9f2390fbe54.jpgPicked this one up store actually had it in stock [emoji23]
Kasal
Galicia, España
I'm a sucker for good tool deals, and I was really curious what aluminum-bronze, non-sparking tools are like. Here's my new set of Bahco Al-Br pliers. I guess I can use them whenever I work on fuel lines.IMG_20180630_130403181_HDR.jpg
Sent from my XT1575 using The Garage Journal mobile app
If you like good tools and are anti-sparking, you should know Ega Master, a Spanish brand of very high quality and with an extensive catalog of non-sparking tools.
Qualitytools
SOCAL
Thanks for expanding on my question, I can sorte see what you mean. I know my sister's old Acura had the type of pistons that had to be turned in order to be retracted and I used a pair of needle nose pliers to rotate them
Lucky13don
Bay area,cali
in the last week a 45pc tekton socket set, mini screw driver set. today at sams club a 12pc tekton screwdriver set. orederd a 1/2" aircat impact, lang 7/16 slack adjuster set, and a 5 pc rachet wrench set.
marineman
Wild Rose, WI
Need to dismantle a ton of pallets an inconvenient distance from an outlet so I made my first foray into cordless sawzalls. Also picked up a few pruning blades for limbing pines I take down and opening up trails in the woods.
Sent from my SM-G930R4 using The Garage Journal mobile app
marineman
Wild Rose, WI
E430Driver
Austin, Tx
I've used my Makita Cordless Circular saw in a pinch. Gonna have to get a sawzall eventually though.
sands2500
Seaside, NJ
Just a little something. But the grease was enough to look like I
was working on my truck. Maybe because of the black oxide? Who knows.
WWheeler
Middleofnowhere USA
These were waiting for me when I got home: Proto JFE700A Spark Plug Boot Pliers. Started out looking for a set of Mac SP700As when these showed up in the search results and look the same to my eyes. Not positive but I suspect the Protos are/were the OEM for the Mac.
d.mcfarland
Western PA
Stanley / Black and Decker owns both, so probably right about that.
u118224
Northern MI
My latest haul from E-Bay. I didn’t “need” the XL combinations but what can I say, I really like Bonney wrenches.
NUTTSGT
FFH had a Tekton sale, 50% off the second tool you purchased. I've been wanting to pick up a 30mm deep well impact socket after I needed one about a years ago so I grabbed one. I also have been eyeing up a set of hollow punches for some gasket making.
NinnyCTSV
Ontario California
Oil filter pliers, weather head sockets, and some 3/4 drive adapters
sweet victory
USA
You sir keep hauling in some rather nice tools, along with good pictures.
I like it :beer:
Thanks! Camera body is a Sony alpha 6300 with a zeiss 24-70mm lens. A close friend of mine moved away, and he would let me use his shop to work on my projects. I had recently purchased a house so he was really helping me out; didn’t have the luxury of splurging on tools. It’s been about a year since I moved, so now that I’m more financially stable, I’m building up my own garage. :)
garthg
Winchester MA
"Bonney"? I thought Matco was made by Wright. They look like Wright.
The extra length is good. You don't have to tug so hard, and you can reach better.
Skin
Boston
Bonney made the wrenches. Wright only supplied sockets and ratchets for a time.
kb1982
Kentucky
The FedEx man brought this today. Autel Maxisys Elite. Dying to play with it but I promised a friend lunch. fe85d59fabfef736469874247ca78f8c.jpg
Sent from my Z962BL using Tapatalk
chrisnazzy
Arizona
Snap-on composite insulating screwdriver set. b26889e70c1ba7eb041c4c718958f4dd.jpg4cc8134813cfcc7f41c7f95da78384c5.jpg
Deep in the heart of Dixie land
Oh man, now you're going to be playing in the big leagues with the EVIL, MONEY GRUBBIN' MECHANICS THAT JUST WANT TO TAKE YOUR MONEY....:lol_hitti:lol_hitti
sweet victory
USA
Amazon purchase arrived today! I have this pinned on my twitter page; there's currently a $5 coupon, making this a $7 purchase. 1m long straight edge with inch & metric units along with some handy conversions.
DSC01077 by P A, on Flickr
DSC01078 by P A, on Flickr
Also modeled and printed a holder for my USA made craftsman mini torx screwdriver set. I can throw this up on Thingiverse if anyone would like a copy of the file. The torx set is only like $10 too :)
DSC01088 by P A, on Flickr
foghorn1966
N. Alberta
A little late going into Canada's 151th. Had to grab one of these because I didn't know that they made a special edition. Especially with all the trade shenanigans going on. A big thanks to Picquic for making these.
Snakebyt
Lubbock Tx
thats a great holder you printed up, does it have recessed magnets or something in the back to hold it there?
dede2897234
Northern, Ohio
Hey Guys,
These are my tool purchases from the past 7 months. Sorry I didn't post them as they arrived. I have been busy with school and work.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/43150167822/in/album-72157668781391637/" title="IMG_20180610_190355383"><img src="https://farm1.staticflickr.com/833/43150167822_e8e487531f_z.jpg" width="620" height="333" alt="IMG_20180610_190355383"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/43150168712/in/album-72157668781391637/" title="IMG_20180610_190125256"><img src="https://farm2.staticflickr.com/1784/43150168712_d319c630c3_z.jpg" width="620" height="222" alt="IMG_20180610_190125256"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/29328269738/in/album-72157668781391637/" title="IMG_20180610_185519312"><img src="https://farm1.staticflickr.com/913/29328269738_52dc2006c8_z.jpg" width="620" height="465" alt="IMG_20180610_185519312"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/43150169052/in/album-72157668781391637/" title="IMG_20180610_185147050"><img src="https://farm2.staticflickr.com/1827/43150169052_8a76f38120_z.jpg" width="620" height="412" alt="IMG_20180610_185147050"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/43150169192/in/album-72157668781391637/" title="IMG_20180610_184701855"><img src="https://farm2.staticflickr.com/1765/43150169192_6bd9057c2e_z.jpg" width="427" height="640" alt="IMG_20180610_184701855"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/42481490284/in/album-72157668781391637/" title="IMG_20180610_184729192"><img src="https://farm1.staticflickr.com/843/42481490284_b55f07310a.jpg" width="379" height="462" alt="IMG_20180610_184729192"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/29328269858/in/album-72157668781391637/" title="IMG_20180610_184847968"><img src="https://farm2.staticflickr.com/1783/29328269858_d324083530.jpg" width="374" height="500" alt="IMG_20180610_184847968"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/43150169262/in/album-72157668781391637/" title="IMG_20180610_184230360"><img src="https://farm1.staticflickr.com/920/43150169262_d762b01421.jpg" width="500" height="302" alt="IMG_20180610_184230360"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/43150168032/in/album-72157668781391637/" title="IMG_20180610_184439921"><img src="https://farm2.staticflickr.com/1825/43150168032_26df18a32c.jpg" width="500" height="352" alt="IMG_20180610_184439921"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/43150168132/in/album-72157668781391637/" title="IMG_20180610_183612813"><img src="https://farm1.staticflickr.com/846/43150168132_855248aa86.jpg" width="500" height="327" alt="IMG_20180610_183612813"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/42481490444/in/album-72157668781391637/" title="IMG_20180610_183637475"><img src="https://farm2.staticflickr.com/1809/42481490444_0d0358b186.jpg" width="500" height="270" alt="IMG_20180610_183637475"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/42481490384/in/album-72157668781391637/" title="IMG_20180610_184041232"><img src="https://farm2.staticflickr.com/1762/42481490384_87ac428a82.jpg" width="500" height="190" alt="IMG_20180610_184041232"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/42481490644/in/album-72157668781391637/" title="IMG_20180610_181706537"><img src="https://farm1.staticflickr.com/913/42481490644_e8a86c859e.jpg" width="407" height="500" alt="IMG_20180610_181706537"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/43150168222/in/album-72157668781391637/" title="IMG_20180610_181920663"><img src="https://farm1.staticflickr.com/833/43150168222_69f31f11a9.jpg" width="500" height="202" alt="IMG_20180610_181920663"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/42481490614/in/album-72157668781391637/" title="IMG_20180610_182346568"><img src="https://farm1.staticflickr.com/918/42481490614_7800cf0df1.jpg" width="500" height="218" alt="IMG_20180610_182346568"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/43151212792/in/album-72157668781391637/" title="IMG_20180610_182617889"><img src="https://farm1.staticflickr.com/836/43151212792_22c1dbce09.jpg" width="500" height="173" alt="IMG_20180610_182617889"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/43150169452/in/album-72157668781391637/" title="IMG_20180610_183444345"><img src="https://farm1.staticflickr.com/925/43150169452_b58fabe080.jpg" width="500" height="375" alt="IMG_20180610_183444345"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/43150168622/in/album-72157668781391637/" title="IMG_20180610_190501190"><img src="https://farm1.staticflickr.com/915/43150168622_94cf7d94de.jpg" width="375" height="500" alt="IMG_20180610_190501190"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/29328270598/in/album-72157668781391637/" title="IMG_20180610_191036435"><img src="https://farm1.staticflickr.com/842/29328270598_7c43649de3.jpg" width="395" height="465" alt="IMG_20180610_191036435"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/43151213112/in/album-72157668781391637/" title="IMG_20180610_191856531"><img src="https://farm2.staticflickr.com/1783/43151213112_b14e2bea1c.jpg" width="500" height="216" alt="IMG_20180610_191856531"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/45102494@N02/43151212692/in/album-72157668781391637/" title="IMG_20180610_192014157"><img src="https://farm2.staticflickr.com/1762/43151212692_cf224de9ac.jpg" width="500" height="160" alt="IMG_20180610_192014157"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
Dave
paulsomlo
Northern Colorado
I have the one with the 2" long bits - the handle is made in Canada, but the bits are Taiwan and pretty soft. I replaced all the Phillips with Wiha brand, quite a difference.
