Re: 70 Yr old couple building a barn (garage/workshop)
Hi Gary. You are right, 4' is all I could find, and is what we used. The place I bought it from also only has it in 125' rolls but they will cut off what you need. I had to get two full rolls and an extra 30'.
It makes it a little harder to work with in 4' sections cause the TIN is in 3' wide. So you have 2' hanging out with 2 sections of tin up, but you catch up and are even on every forth section.
I think their reasoning for 4' wide is because of it being used with 4' x 8' sheating. Some of the brands come with a glue tab to seal the seams. Also they sell the aluminum tape seal the seams etc. Astro has the tape in 2 and 3 inch wide and really sticks the way it should.
I'm from Cincinnati Ohio. I have found some similar but it is 4' wide and 125' long.
Thanks for the info, you are doing a awesome job thanks for sharing.
Gary
