Dumb newbie question
gorilla
#10 goggles might protect your eye's but won't do much to protect your face from the UV radiation from the arc. PPE for welding is not a good place to go cheap.
MoonRise
Actual goggles are NOT the appropriate PPE for use when arc welding (MIG, TIG, stick, any welding process using electricity).
Arc welding produces heat (to weld with) and intense light, both visible AND ultraviolet (UV).
For arc welding, you need a 'welding helmet'. The facemask part of the helmet protects your face from heat and UV and molten metal spatter.
Welding goggles are typically a Shade#5 and are usually appropriate for use when oxy-fuel welding or brazing or soldering.
jhn9840
Northern Panhandle of WV
#5 would be to light at least for me. If you are talking about cutting goggles I wouldn't use those for mig welding. TSC or Harbor Frieght usually have some cheap welding hoods.
jhn9840
John
bubinga
When I started I found an auto darkening helmet made it work. I couldn’t use the always dark shield
Yes, I think auto darkening will be the way to go.
I want to be able to see my gun and work before I hit the trigger.
What do you recommend for an auto darkening helmet that won't "break the bank"?
Sent from my MotoG3 using Tapatalk
bubinga
I should probably have a welding coat, right, so as not to "sun burn" my arms too, is that correct?
Thanks.
Great bunch of people here.
bczygan
DETROIT! Arsenal of Scrappers
Harbor Freight Vulcan helmet. Use Vulcan 20% coupon.
Your question brings up one from me.
If using the above helmet for oxy/acetylene work, what is the right setting?
Bill
jhn9840
Thanks.
I just use an old flannel shirt. It works as long as you aren’t doing a lot of overhead welding.
jhn9840
John
OccupantRJ
Eastern North Carolina
A long sleeve denim shirt with snaps has always previously been the standard shirt for welders on the construction jobs I was on. Quick to unsnap the shirt when you are not welding to cool off a bit between rounds if you are wearing a T shirt underneath.
bubinga
jhn9840
John
Great!
Thanks guys
Thanks for the advice on the helmet too.
I have a - 20%. Coupon on my phone too.
Need to follow up on the trailer wheel recall, (2 on the trailer, And A spare) need to make a HF run soon
OccupantRJ
I have used one of the $45 HF auto dark helmets in my shop for 8 years or so and have been satisfied with it. I have put 2 batteries in it over that time.
bubinga
bczygan
Talking about this one I guess.
Only one I see.
That's a Good thing.Not a million choices.
https://www.harborfreight.com/arcsafe-auto-darkening-welding-helmet-63749.html
Yes!
With this coupon:
Bill
Kaizen
New England
Like said hf one works. Think I got mine at Lowes or hd. Mine has settings that I can grind with it as well as weld. So when set to grind it does not darken. I hate that setting. Always forget to turn it and get a nice flash burn. So don’t pay extra for it.
Mine I think was forty.
For oxy I use just goggles. I normally do it outside so I can see a little to get going.
One bit of advice. Close your tanks when you stop working. I learned the hard way that it will leak out of the machine even if the fittings are perfect. Nothing worse then losing a whole tank of co2/argon for being lazy
Kaizen
New England
Regarding clothing. Good gloves obviously. In winter I wear carhart jacket. Normal winter jacket. Summer I have leathers that I use as I’m tired of having burns in every shirt I own. They sell just sleeves that you can use. Not sure of cost. Wear boots. I constantly wear sneakers and always have slag burn through the sneaker and sock and burn between my toes.
And a cheap welding beanie. With the mask down I get sparks on my head.
Buy as you can. You will figure out what you need as you get burned. Not being wise. Everyone’s position and setup is different so everyone has different needs
bubinga
Sounds good.
Thanks,
bubinga
