chinesse scroll compressors
dogdog
does it run, or attempt to start? or does it trip out when power is applied? details if you want the armchair engineers to be able to diagnose anything :)
not sure what good that would do him if he only has 110V service.
OP might have 220 at his home available and don't even know about it... just like most of the people in the USA here don't realized they have 220V a(ahmm 240V), then again never been there and won't know...
Scroll down to the country that says Columbia
https://www.trade.gov/mas/ian/ECW/all.html
u3b3rg33k
he says he doesn't have it at his farm. i would hope he looked in his breaker box before doing a group buy of compressors...
dogdog
Nop.... 220 v is not available at all homes....
In my house I have 220v, at my warehouse (mans cave ) I have 220v, but at my country house or farm I have 110v.
Colombia is not a Banana Republic anymore.... At rural places if you ask for 220v they install it but not cheap
I did not want to pay around US$ 400 to install 220v in my farm so I can operate a lousy compressor ...
How much do you know about Colombia ?
You are right he did say it on post 29... oh there goes that idea ....
EOC_Jason
Bentonville, AR
I have to agree with above... A 30-amp breaker for a 3HP/3.5HP motor @ 110V is not large enough... You would need *at least* a 40A, and even that might be too small...
tthornto
the 80 amps on the clamp is when the motor is trying to spin. it nevers really starts.
I am neither an electrician or an electrical engineer but that sounds like a bad/incorrect capacitor on the motor.
Would the capacitor need to be different because he went with the 120v motor?
Did you make sure it has oil in it? Is there a way to turn it over by hand (with it turned off) for a few revolutions to be sure something isn't locked up mechanically?
Hdonly0
Northwest Florida
Electric motors draw many times the full load amp rating at start-up. If the wiring is too small, the amperage will increase even more because of voltage drop. Increase wire size and breaker rating and all will be fine.
3robert 1
Eastern Ontario canada
Just looked up the chart on this 3 hp 110 volt draws 37.9 amps start up 4 hp draws 49 amps on startup. So if the motor is 3.5 hp you might barely get by with a 50 amp breaker though I would suggest 60 amps . I can't remember what code says about size of breaker.
dogdog
well on OP's post #68 he had a pic of that motor with a tech plate....
Maybe he can get a clearer pic of it and post it up even if those things are in KW ratings, some one should be able to translate it....:)... man hope this doesn't turn into a dud..
this pic....
But I think slkay944 is right their web site have the lowest model is 220/60/1 or 220/50/1 2.2KW for the JYGL-03 / JYXG-03 model All other are 3 phase..
J
Jvvmusme
Bogota, Colombia
you are right. i need to calculate capacitor for 110v 3.5 hp motor
Marctrees
TX/LA border - Toledo Bend
Jvv - I just want to say... some of us, me included, do make a bit of fun about this, because of China, ...But the collective GJ Brain does want to and WILL help you get this done.
Marc
Marctrees
the 8 gauge wire is from the wall socket to the machine?
From the breaker panel to the plug in receptacle ("Wall socket"... If Any) is I understand what the experienced guys are saying.
And ALSO to the machine.
So, allllll the way breaker to machine.
You tech guys please correct me if I am wrong.
Marc
scooby074
Nova Scotia
Were going to need a closeup of the motor nameplate. The nameplate on the enclosure as well (if there is one).
Im hoping they didnt send you a 220v compressor either intentionally or by accident. That would be the first step, knowing what you got. Then we can go from there.
EOC_Jason
Bentonville, AR
From the breaker to the machine....
You shouldn't have to change the capacitor on the motor... Every dual-voltage motor I've used you left the capacitors alone when switching voltage.
dogdog
Their website also says they will have after sales support until issue is resolved.... usual turn around is 24 hours .... maybe the OP can email them... as far as the motor... unless it is a special order... 110V is not available as a choice in website..
J
Jvvmusme
Bogota, Colombia
Where is a picture of the motor data plate?
What is the brand and model#?
Isthere existing caps?
Type: ML 901-2
Kw: 2.5
H.P. : 3.5
V: 120
A: 27
Ins.CL: F
IP: 55
Hz: 60
S: SI
R/min: 3480
80 MF 250v
600 MF 150v
Able Electric Co.
exmaxima1
Midwest
Yes, capacitors are not the problem. Unless bad from the factory.
And you would think that they would be fine, as they are essentially the key product line of the compressor's manufacturer: Wenling Jiayang Capacitor Co, Ltd
3robert 1
Just did the calculations again using the rating off your motor plate. Based on that 45.4 amps draw at 110 volts. I'm not an electrician but have worked in electronics all my life so I'm comfortable using the formulas. Based on the requirements I think you need a 60 amp breaker, anything less will trip on startup.
J
Jvvmusme
Bogota, Colombia
I will try, but at a different location another of the compressors does not trip on start up but shuts down with a message "motor overload". almost the same...
EOC_Jason
Bentonville, AR
What wiring / breaker is he using?
Problem is when you are running undersized wire you are going to get a voltage drop / increase in amps, which if it doesn't trip the breaker it will cause the motor to run hot...
If your breaker panel is in the garage or somewhere with easy access, try a temporary setup with a larger breaker & wire size as has been suggested. If it runs properly then you can run a more permanent setup to where it needs to be.
May Pop
Lake in the hills Il.
Looks like 27 Amps on the name plate but I could be wrong. Minimum fuse or breaker size would be 27 x 1.25 = 33.75. (Largest motor in the whole machine).Next common fuse/breaker size is 40 amps. Are there any motors or loads in the compressor like fans or driers? They get added to the total Current/amp draw. The motor can actually be fused at 250% of full load amperage. This is to overcome startup.
TRWham
East Cobb County, Georgia
Because capacitors are usually rated in DC voltage, and the peak it will see on AC is higher than the nominal line voltage. The nominal AC voltage, in this case 110V, is only the root mean square (RMS) of the peak to ground (or half of peak to peak). A capacitor will be charged at peak, which is about 155V for a 60Hz 110V RMS supply. This one appears to be rated in AC.
ETA: start capacitors can be pretty marginally sized by OEMs as they are not under power for very long.
EOC_Jason
Bentonville, AR
The pictures show a fan mounted on top, and then there's the electronics...
