May Pop
The motor has a tag on it. What does it say for voltage and amps?
" 个鸡蛋只狗 "
Marc
does it run, or attempt to start? or does it trip out when power is applied? details if you want the armchair engineers to be able to diagnose anything
not sure what good that would do him if he only has 110V service.
Nop.... 220 v is not available at all homes....
In my house I have 220v, at my warehouse (mans cave ) I have 220v, but at my country house or farm I have 110v.
Colombia is not a Banana Republic anymore.... At rural places if you ask for 220v they install it but not cheap
I did not want to pay around US$ 400 to install 220v in my farm so I can operate a lousy compressor ...
How much do you know about Colombia ?
he says he doesn't have it at his farm. i would hope he looked in his breaker box before doing a group buy of compressors...
the 80 amps on the clamp is when the motor is trying to spin. it nevers really starts.
according to their website it is 220/50/1 --- 220v
I am neither an electrician or an electrical engineer but that sounds like a bad/incorrect capacitor on the motor.
Would the capacitor need to be different because he went with the 120v motor?
Did you make sure it has oil in it? Is there a way to turn it over by hand (with it turned off) for a few revolutions to be sure something isn't locked up mechanically?
the 8 gauge wire is from the wall socket to the machine?
From the breaker to the machine....
You shouldn't have to change the capacitor on the motor... Every dual-voltage motor I've used you left the capacitors alone when switching voltage.
Yes, capacitors are not the problem. Unless bad from the factory.
Just did the calculations again using the rating off your motor plate. Based on that 45.4 amps draw at 110 volts. I'm not an electrician but have worked in electronics all my life so I'm comfortable using the formulas. Based on the requirements I think you need a 60 amp breaker, anything less will trip on startup.
I will try, but at a different location another of the compressors does not trip on start up but shuts down with a message "motor overload". almost the same...
why?
Looks like 27 Amps on the name plate but I could be wrong. Minimum fuse or breaker size would be 27 x 1.25 = 33.75. (Largest motor in the whole machine).Next common fuse/breaker size is 40 amps. Are there any motors or loads in the compressor like fans or driers? They get added to the total Current/amp draw. The motor can actually be fused at 250% of full load amperage. This is to overcome startup.
