My first real shop
Redlig
Jacksonville, FL
Hey everyone my names nick. So I have lived in a development long enough and finally we moved. The property we purchased has a detached garage and this is a thread I'm starting to record the changes and get input. This is that I started with not a bad start. First off was gut it then put in eletrical. I had my power company run a desperate service for it. After eletrical I did spray foam insulation then started working on the walls. Also move in the new compressor and new to me "workbench"
R
Redlig
Jacksonville, FL
looking good, are you going to do the corrugated tin/plywood treatment on all the walls?
That's the plan as of right now. I wanted something that would do well against sparks plus I can pull the metal off and still do eletrical work if need be in the future
R
Redlig
Jacksonville, FL
I want to do some trim to clean up around the doors/windows and where the metal meets the wood. However I'm debating painting the plywood. What do you guys think. Oh and here's some of the stuff I have built/refurbished
R
Redlig
Jacksonville, FL
Here some practice metal working I did the first pics are a backbone to a drift trike the last one is a brake linkage I made
R
Redlig
Jacksonville, FL
Well got my walls up and all my trim stained. All that is left is to whitewash the plywood upper half do the trim and I'll be moving my stuff in. I have a few things at my work I have to move in like my welders welding bench band saw and took box ect. When I moved it was easier to store at work during the move instead of storage. I made a rolling work bench that I'm going to convert to My welding bench. I have a 3 x 5 half in steel top for it. Here's a few welding practice shots while I wait for better garage update pics
Edit: oh and I gotta finish getting the mini split ac going cant wait for that
C.L S2000
LB, CA
Odd question, but where do you get the seats for the tricycles?
R
Redlig
Jacksonville, FL
so what size is it?
The building is roughly 16x25
Got some work done today after work haha started white washing the upper walls and got the trim stained. Not sure if I should do another coat of white wash. Not everyone likes it but I like the mix of light and dark wood
R
Redlig
Jacksonville, FL
Made some progress today after work now you can kinda see what I have in mind. Went ahead and completed one wall so I can move the big bench there and take up less space
OP15
Maryland
Looks good. The trim will look better once it's all up (no rush!). I'm digging the Honda I have an old trail 90 in the shed. Was a fun bike but I bet yours is a blast
R
Redlig
Jacksonville, FL
Yeah I love them I built two 1971 c70 passports one for my dad and one for my wife. Hers is pretty sweet I'll have to get pics
R
Redlig
Jacksonville, FL
Here is my wife's honda and my bike. And the messy storage area(attached garage). Using it to stage shop stuff. The yellow bike was the day I got it. She was surprised at the differance
R
Redlig
Jacksonville, FL
Made some more progress. Not much but moving around the end is getting in sight
R
Redlig
Jacksonville, FL
Nice air compressor man, those are quality.
I delt with a 20 gallon for so long and once I did more "side" welding work I got sick of it. I've used it with my air cut off wheel to do all the sheet metal on the walls. It was sweet running an air tool without the compressor running forever and constantly. It actually shut off while I was running a tool...made me smile lol it's the littl2 things in life
R
Redlig
Jacksonville, FL
Well I feel like I got some real progress done today. 2 small walls and a big wall are completely done aside from touch up on the stain and paint. Compressor is off the pallet and I started plumbing it. Wood work bench is cleaned off. Oh and router is installed with the camera. There was conduit run from the house to the shop. When I pulled the old wire out of it I used the same conduit to run cat6 to the shop then put in a router. I figured since I had a separate service now why let it go to waste.
R
Redlig
Jacksonville, FL
Guess who has two thumbs and started running air lines....this guy haha
R
Redlig
Jacksonville, FL
Not quite sure how to "store" the dryer the shelf it is on is one I made but it's not quite deep enough. Also finally gonna have a little decorations. Some hess trucks I have had most of my life here are a few I have
zkling
Wow, don't think I've ever seen someone pimp a Honda Passport. :lol_hitti
R
Redlig
Jacksonville, FL
Go buy 3 hockey pucks, and put them under the feet of your compressor, half the noise will go away.
Uh....seriously haha that will literally be the only sporting good type thing I have ever bought.
And yes the dryer is for the air. I plumbed it so I can run on "straight" air or the dryer. Started the end aswell
rattle_snake
Chandler, AZ
Only bolt it down if needed (moves around on the floor). If you do, use rubber isolators top/bottom as to not stress the feet and crack the tank. Don't over torque.
R
Redlig
Jacksonville, FL
Do you guys think I could put pucks/rubber under the feet and not bolt it down? Right now it doesnt walk. I'd rather not bolt it down just for convenience.
R
Redlig
Jacksonville, FL
So I finally have all the walls done. Ahhhhhh it's been so nice working in the a.c. haha. I also did some work on the double doors. Took a little break today and went out on the boat and also used the shop some to make another piece of furniture for my wife. Were really into uh idk what youd call it functional rustic haha
R
Redlig
Jacksonville, FL
Finally making some progress. Getting there...cant wait to get my tool box in and get the rest of my **** organized.
R
Redlig
Jacksonville, FL
Ahhhhhh finally light at the end of the tunnel
C_F
Utah...SNOW BLOWS!
Looks good in there! :thumbup:
I can't figure out what the green & silver cone shaped thing is by your man door. Is it a heater?
R
Redlig
Jacksonville, FL
Haha that is I think....a 1948 vornado fan if anyone knows better correct me please. That's the closest to dating it I have come
bj383ss
TX
What a cool shop. On the compressor feet. I bought the isolator pads at Lowes and then bolted mine to some 2 x 6's and then bolted one of those to the wall. Mine moved around quite a bit it liked to dance I guess. I really like your setup and the fan is neat.
Bret
tre873
NE TX
What about drilling a recessed hole in the hockey pucks and then bolting them to the compressor feet? I would think it would absorb vibrations and help keep the compressor from moving.
